estate bits needed
Started by ffcgary1, 21 June 2013, 19:36:36
ffcgary1
I need to replace the antenna rubber base gasket on my pfl estate, as it has seemed to have shrunk and split so need to replace asap.
Anyone breaking an Estate and have this part pls, if not a trip to the breakers might be needed or a trip to the stealer.
Can pay via pp or however you want.
Gary.
Jaguar XJ6
If you search Ebay for 'Vauxhall aerial base' you'll find new ones for  a fiver. Which makes scratching around for a used one daft.
Shackeng
Pardon the Hijack! My PFL Estate aerial base has gone also. Are these easy to swap? :-\
Shackeng
Quote from: Shackeng on 22 June 2013, 09:12:01
Edit: should read MFL, but I guess they're the same.
Remove the central plastic trim (release the tops of the side trims then manoeuvre it out ), pop the interior light out and there's enough give in the headlining to get to the connectors and retaining nut
