Author Topic: clunking and knocking  (Read 3942 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« on: 22 June 2013, 14:52:40 »
Right then.... the above mentioned noises where present before i changed the wishbones, drop links, steering idler and front struts and springs.... only things i havnt changed are the tie rods and centre bar thing but the kind of noises im getting wouldnt be them anyway so what else can it be?
Re: clunking and knocking
« Reply #1 on: 22 June 2013, 16:20:23 »
Strut top mount bearings maybe ?
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 22 June 2013, 16:49:28 »
+1 :y or car not on ground when wishbones tightened up ;)-probably had front end up on stands when wishbones tightened
chrisgixer
« Reply #3 on: 22 June 2013, 19:47:17 »
What kind of noises? In time with road bumps? Or steering movement? ...guessing not road wheel speed from the title...?
If everything s tight and torqued correctly;
Play in the centre tie bar, track rod ends
Loose bumper or wheel arch liner
Wheel bearing play
Calliper slider wear
Loose pinch bolts from knuckle to wishbone pin
Or any bolt torqued too low
....Can all give mid knocks over bumps.
Knocks and creaks during steering input can come from the steering box bolts to body, and likewise from the steering idler bracket to body.
No experience of top shock mount faults, but I'm sure they can knock too. Are they, and everything else, tightened correctly? Etc ? :)
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 22 June 2013, 20:05:30 »
Wheel bearing play
has plastic body with ridges around outside-they wear down allowing movement ;) especially v6 migs
vauxsull
    • 3.0 Elite
« Reply #5 on: 22 June 2013, 20:46:50 »
oh jeez so much to think about here.... as i said noise was there prior to replacing all the bits i mentioned... think i shall either let it develop so i can pin point it or take to garage and let them look...
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 22 June 2013, 20:51:15 »
did you change parts or garage mate
vauxsull
    • 3.0 Elite
« Reply #7 on: 22 June 2013, 20:52:26 »
symes
  • oxford
    • R reg 940 volvo
« Reply #8 on: 22 June 2013, 20:57:58 »
did you change wishbones etc or did garage do them
chrisgixer
« Reply #9 on: 22 June 2013, 20:58:29 »
Did you do the work yourself ?
I must admit I presumed diy, so a loose torque setting might be more likely to be repeated in correctly, or sumat not done up tight enough before AND after.
But if a garage did the work... actually, could also be likely something is still loose before and after, if the same garage is always used. Perhaps?
You've not really given enough info about the noise tbh.
vauxsull
    • 3.0 Elite
« Reply #10 on: 22 June 2013, 20:59:05 »
i seeeee i did them with a mate ..
vauxsull
    • 3.0 Elite
« Reply #11 on: 22 June 2013, 21:01:43 »
hard to explain what the noise sounds like in text... can only say its a clunk.. only when turning wheel not travelling along... no vibrations when driving or any wandering about..
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 22 June 2013, 21:01:57 »
so was car on ground before you tighten up wishbones--probably no--that is whats wrong--car needs to be on floor-all wheels on ground before you tighten mounting bolts for wishbones :y
vauxsull
    • 3.0 Elite
« Reply #13 on: 22 June 2013, 21:05:26 »
right then so is it a coincidence the noise is the same before and after the wishbone change? if i get someone to do it for me whats the torque sequence for them and what Nm and they set at?
symes
  • oxford
    • R reg 940 volvo
« Reply #14 on: 22 June 2013, 21:15:14 »
Page created in 0.052 seconds with 14 queries.
