Wynns Lifter Fluid in solid valve train
Started by Webby the Bear, 23 June 2013, 11:32:23
Webby the Bear
Hi guys,
if a car has a solid valve train i.e. rocker shaft as opposed to hydraulic lifters would the engine still benefit from sticking some wynns lifter fluid in?
obviously I know there no lifters to ''declogg'' but would it help in other areas like gunk in oil galleries for example?
RIP Paul Lovejoy
symes
Webby the Bear
Quote from: symes on 23 June 2013, 12:06:58
no point in using it mate IMO
Fair play mate, I shan't bother then  :y just wondered if it would help with any other crap build up in there  :y :y :y
RIP Paul Lovejoy
symes
Webby the Bear
RIP Paul Lovejoy
symes
ah you should run engine-take it for a run-to get oil warm-then drain ASAP-hot oil drains better mate  :y
Webby the Bear
RIP Paul Lovejoy
symes
wear eye protection and careful-oil burns mate :y but you should be ok-even olivia can do an oil change-rover-she done 2x now :y
