Author Topic: Clearing fault codes  (Read 1762 times)
Joiner
  • Leighton Buzzard, Bedfordshire
    • Omega 2.6 V6
« on: 24 June 2013, 11:05:11 »
Hi all,
1, 3, 5 coil packs gone up the swanny. After doing the pedal trick its reporting random misfire and a misfire on pot 5. If I change the coil pack will this error code clear by itself or do I need to get a diagnostics unit on it to clear it. The engine management light isnt on but did flash when at high revs.
Engine is the Y26SE btw.
Cheers
Re: Clearing fault codes
« Reply #1 on: 24 June 2013, 11:07:38 »
IIRC, misfire ones do not clear by themselves.
Joiner
    • Omega 2.6 V6
« Reply #2 on: 24 June 2013, 13:59:54 »
Cheers for that TB :y
Next development, changed coil pack, runs a treat, did the pedal trick to check for fault codes and it now flashes continuously. Is this normal? ???
« Reply #3 on: 24 June 2013, 14:01:38 »
Yep
« Reply #4 on: 24 June 2013, 14:03:07 »
Well, obviously the misfire ones do clear pretty quickly then ;D
« Reply #5 on: 24 June 2013, 14:04:11 »
I'd love to get a Tech2 on that to see if the codes are still there, but not appearing in pedal trick, if ever you pass Brackley (or MK on weekdays)
Joiner
    • Omega 2.6 V6
« Reply #6 on: 24 June 2013, 14:05:45 »
Going to Wymbush MK tomorrow...................... 8)
« Reply #7 on: 24 June 2013, 18:09:48 »
Tomorow, or the next 10 days aren't good for me, as I'll be going to sunnier climbs.... :D
I work in Bletchley, so given your location, I'm sure something can be arranged on my return :)
Joiner
    • Omega 2.6 V6
« Reply #8 on: 25 June 2013, 10:21:24 »
Yep
Happy days!
Cheers Rob :y
I did disconnect the battery tho for about an hour so maybe this clears it? ???
I live in Leighton Buzzard so I'm sure it can :D :y
« Last Edit: 25 June 2013, 10:24:20 by Joiner »
