Starting Problem ?
Started by omega3000, 24 June 2013, 14:27:43
Yes on the Vectra again  >:( Anyway only since i put a bottle of redex petrol treatment in its been struggling to start from hot , just keeps cranking then if i stop it and try again it starts :-\
BazaJT
Suffering fuel vaporisation due to under bonnet temperatures?Do modern engines suffer from this?
old imjectors may leak when hot.. and you can hardly see on leak tests..  happened to my omega
martin42
Does this happen after a short journey,ie to shops?
You know I think that someone, somewhere, is sending you lots of little hints, that you really need to go out and buy another Omega....  :-\  ;)  ;D
martin42
Must try harder to stop car working lol
Quote from: magic tree 42 on 24 June 2013, 22:24:36
Aye , but ive been cleaning the throttle body . Short trips say about a mile or so a day , maybe the battery needs a good charge from a longer run as it could be zapping all the juice out of it with all the short runs  :-\
Quote from: Sir Tigger on 24 June 2013, 22:26:11
I wish mate  :-[ :-[ :-[
martin42
Seems like the same problem pumas have,before starting wait 10 seconds before cranking engine,and then start it,see how that goes  :y :y
Quote from: magic tree 42 on 25 June 2013, 05:59:49
Will give it a go , cold starts no problem . Mite pull the plugs and check them  :-\
