Author Topic: 2.2 Exhaust Manifold Stud  (Read 1429 times)
« on: 25 June 2013, 20:56:04 »
My lad has been stripping the ancilliaries etc down to remove the Head and managed to remove all the Exhaust manifold nuts & studs barring one! The one causing the trouble is under the manifold in line with the Power Steering Reservour so not visible and he has rounded off the 13mm copper nut and the stud torx end! Do any of you Oof spanner wizards have any wisdom to impart to enable removal of the offending article (the stud, not my son ::))
b4ndit
Re: 2.2 Exhaust Manifold Stud
« Reply #1 on: 25 June 2013, 21:11:59 »
Try an Irwin socket that should shift it :y
« Reply #2 on: 25 June 2013, 21:14:33 »
+1 :y - Look Here  ;)
« Reply #3 on: 25 June 2013, 21:52:30 »
Brilliant! Thanks fellas :y
Just ordered a set :y
« Last Edit: 25 June 2013, 22:03:58 by PhilRich »
« Reply #4 on: 25 June 2013, 22:17:37 »
Fatty up the road has a set, forget what i used them on, but they worked very well. Highly recommended :)
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 25 June 2013, 22:21:18 »
not any more if he see's this ;D
Page created in 0.242 seconds with 16 queries.
