Author Topic: MV6 Estate seats to saloon ?  (Read 4331 times)
Big_Al
« on: 25 June 2013, 21:25:38 »
Hi guys ,
              looking for some confirmation here  :-\
May have found a decent set of leather MV6 estate seats & door cards for my '51 plate MV6  saloon from a Y reg MV6  estate
Been searching on here for relevant info as to what fits & what don't .
Am thinking that fronts are the same . . .so no probs there I hope
Rear seats   .  .absolutley  no chance I know  :(  but will a set of leather rears from any saloon F/L model fit ? CD CDX or elite ?
All 4 door cards are also available . I think estate & saloon are interchangable but is there any  cosmetic difference on the leather interior cards to the standard cloth trim ones ? :-\
TIA     Al  :y
kevinp58
  • kent
    • 2002 3.2 elite
Re: MV6 Estate seats to saloon ?
« Reply #1 on: 25 June 2013, 21:37:58 »
They should do as all the frame fixings for saloon should be the same, i;e fl should all be same as any other fl . Not sure if the wiring harness will marry up though.  :-\
« Last Edit: 25 June 2013, 21:48:45 by kevinp58 »
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 25 June 2013, 21:44:05 »
Both cars are fl, front seats will fit,just need to follow the guide in how to section for wireing up the seat motors. All f/l door cards are the same will fit either estate or saloon.
 you should have the wireing in the back allready for rear seat heaters :)
« Last Edit: 25 June 2013, 21:46:01 by biggriffin »
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 25 June 2013, 21:50:12 »
 May not have the switches fitted though.  :-\
« Reply #4 on: 25 June 2013, 21:51:14 »
Everything upto back doors the same :y
Big_Al
« Reply #5 on: 25 June 2013, 21:51:29 »
Biggriff . . would you know if there is any difference in the cosmetic appearance of the cards fitted to leather interior cars or are the cards all identical in appearance on both  cloth & leather . no point in me changing these if thats the case  :-\
biggriffin
« Reply #6 on: 25 June 2013, 21:55:18 »
If they are from a car with black leather they will be a grey/black trim with either fake wood or silver trim,me thinks.you want the shop keeper mr robg to wander past and hope he has a photo. :)
Hoof'land storeman.
Big_Al
« Reply #7 on: 25 June 2013, 21:59:40 »
Grey/black trim with silver inserts is what I have with the present cloth trim fitted. So no need to fit those then  :) :)
thanks.
Just need to clear up this point that was posted  about motor wiring now  :-\ :-\
biggriffin
« Reply #8 on: 25 June 2013, 22:09:40 »
elite leather seats have electric height,recline,for n arft.
Theres a guide in the how to section :y
Hoof'land storeman.
Big_Al
« Reply #9 on: 25 June 2013, 22:13:52 »
But am fitting  leather  from a FL  MV6 to my FL MV6  cloth trim car  . . .  so wiring should be the same  . . .  .should it not ? :-\ :-\
« Reply #10 on: 25 June 2013, 22:18:44 »
Correct
Big_Al
« Reply #11 on: 25 June 2013, 22:20:20 »
Correct
Happy days  . . .thanks all  8) 8) 8)
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #12 on: 25 June 2013, 22:21:13 »
[/quot
If the seats you have are MV6 Leather they should fit no probs do the leather seats have memory buttons if so they will be the same as elite seats if no memory buttons they should just plug straight in.  :y
sideways steve...
  • gravesend, KENT
  • hi there .
    • 3l mv6 manual estate 1998
« Reply #13 on: 27 June 2013, 07:50:02 »
hi there .
i got an mv6 estate which had leather seats which i have now changed for the dark cloth ones .
but the only dark cloth seats i could get hold of came out of a saloon .
yes front seats straight in no probs .
back seats needed some work to make them fit as soloon and estate  rear seats compleatly different.
but as i spent 20 years as an upholsterer making them fit was not as hard as i thought i would be .
used the estate seat frames and cut and machined the covers to fit .
result. more comfy and better looking than the old black leather
« Reply #14 on: 27 June 2013, 22:08:49 »
Leather seated cars have matching vinyl leather door panels regardless of spec :y
