PAS sytem. Refill and bleed advice
Started by Webby the Bear, 26 June 2013, 06:30:45
Webby the Bear
Hey gays, hope you're all good.
How do you guys do the above? I fitted a new PAS pump to my mate's Hyundai Coupe and when I fitted the new part and refilled the system it sounded like SHIIIIIIIIIIIIIITE!!!!!! Even at idle it was screeching and clunking  :o
I went about bleeding the way I thought it was to be done..... turn steering lock to lock a few times with the lid off the fluid reservoir and I left it to idle.
the noise was that bad I actually thought something was seriously wrong  :o luckily the job is a 5 minute one so I popped the old one back on and that made a little bit of noise initially and then settled down fine (apart from still exhibiting the reason for it's replacement of it screeching at full left lock).
Anyway I was thinking about this and i'm wondering if I simply didn't bleed it well enough instead of condemning the eBay part as junk. What do you think?
Remember as always i'm still learning so your methods baby-fied please :)
RIP Paul Lovejoy
martin42
Sounds like eBay part was bad,right method of bleeding system tho  :y
Webby the Bear
nice one mate. I thought so. its also odd that putting the old one back responded to my method of bleeding - that's why I was so quick to condemn the eBay part.
ive asked him to bring it over again as I want to be doubly sure so ill pop the ebay part on again and have a play.
I believe these can be ''remanufactured'' somewhat so I may take it apart and see if I can repack the bearings.
oh the joys of auto repair  ::)
RIP Paul Lovejoy
henryd
Quote from: magic tree 42 on 26 June 2013, 06:55:30
+1 all you can do is lock to lock to bleed it :y
other rides
Seth
Quote from: henryd on 26 June 2013, 11:04:22
Even better if you do this with the front wheels off the ground! ;)
martin42
Being WWD it can't pull a wheelie so can't bleed ps that way  :D ;D
Webby the Bear
lmao. yeah i'm fairly sure it cant do that.
ok two questions that are on my mind....
1.) when I get the new part (gonna get one from a motor factors for him) would it be sensible to prime it with PAS fluid so its not dry on initial start up?
2.) someone on a Hyundai forum mentioned an air bleed nipple on the rack itself.  ??? i'd never heard of this but I suppose it makes sense. anyone else heard of this on any car?
:y :y :y :y
RIP Paul Lovejoy
martin42
Just fit pump dry,still have fluid in system,so only top up pump once all connections done,if you want turn pump by hand a few times,then fit aux belt and bleed system
symes
it is possible to have a bleed screw in rack-have a look-what you could do is pour oil into pump-first-messy but fun :y
Webby the Bear
lol yeah it did get messy. it missed the rags i'd put down and went on the road  :-[
Ill have a look for a bleed screw but even if there is one it should have bled out using lock to lock method, right?
RIP Paul Lovejoy
symes
turn full lock-undo bleed----but dont hold  full lock too long-not good ;)
