Author Topic: how to setup throttle adaptations on a 2001 2.2 petrol  (Read 2237 times)
Shandyman
  • Prestwich,Manchester
    • 2001 2.2 CDX Auto
looked on Op COM and i cant get it to work
have also tried bosch KTS,  snap on solus plus and VCDS.......nowt works
« Last Edit: 26 June 2013, 20:27:35 by Shandyman »
Re: how to setup throttle adaptations on a 2001 2.2 petrol
« Reply #1 on: 26 June 2013, 20:51:49 »
What exactly are you trying to achieve :-\
chrisgixer
« Reply #2 on: 26 June 2013, 23:31:03 »
adaptions mean just that, they adapt, to your driving style or whatever.
I doubt its something that can be fiddled with...?
Shandyman
    • 2001 2.2 CDX Auto
« Reply #3 on: 27 June 2013, 00:44:40 »
Ok .,roller disintegratred took belt out, valves and guides ...all have been replaced.the problem I've got is that it that it starts but cannot clear or reset throttle adaptionsp
« Reply #4 on: 27 June 2013, 11:02:19 »
There shouldn't be any need to touch anything in the ECU following a rebuild.
You can reset block learning and, on some ECUs, idle valve learning but I'm not even sure if that would be relevant to a drive-by-wire engine. In any case, these are only required for diagnostic purposes in specific circumstances and not following a cam belt failure.
Please let us know what symptoms you have which might indicate a problem (you say it starts - does it drive ok? any trouble codes in the engine ECU?) and we'll do our best to help.
« Reply #5 on: 27 June 2013, 14:50:24 »
If it does need doing I wouldn't want to do it using a Chinese O---m device either.Way too risky imo.  ;)
Shandyman
    • 2001 2.2 CDX Auto
« Reply #6 on: 12 July 2013, 19:48:01 »
Faults I have are throttle position sensor and adaption faults.engine starts and runs fine but won't rev....!after 15-20 mins cuts out....cannot get throttle actuator to operate At all even though it has been changed
« Reply #7 on: 12 July 2013, 19:51:03 »
Anything be done to throttle body?
  • Auckland
    • Mazda MPV
« Reply #8 on: 12 July 2013, 20:42:49 »
"Throttle adaptation" is term I have seen used on VW forums. I don't think it has any relevance to Vauxhalls.
If the software is using the term "throttle adaptation" then it does tend to reinforce concerns that the software isn't fit for purpose :-\
Most likely cause is damage to the wiring or throttle body while the engine was out (or maybe someone forgot to plug the connector into the throttle body ::) you wouldn't be the first..........)
Vitaliy
  • Knezha, Bulgaria
    • OpelOmega B 2.5 v6 Estate
« Reply #9 on: 12 July 2013, 21:28:44 »
Hi
its probably a stupid suggestion - but have you by any chance used wrong connector!!! had same trouble when was assembling my engine long time ago and  PFL omegas with square plugs use same plug on Camshaft positioning and throttle positioning sensors. ECU would not always store CPS error but would not run above 4000rpm.
