Author Topic: 2.6 Automatic cuts out and restarts after 10 mins  (Read 3791 times)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: 2.6 Automatic cuts out and restarts after 10 mins
« Reply #15 on: 29 June 2013, 15:56:22 »
Brian,
Re getting a CS from Dingro. The advice here, which I have followed after my CS failed, is to avoid early failure of a pattern CS and buy a genuine VX CS.  :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #16 on: 29 June 2013, 16:52:55 »
ok will do,have to wait till monday call around hopefully get one then,many thanks
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #17 on: 01 July 2013, 20:33:29 »
so got new crank sensor delivered to garage from dealers £54 in total not bad i reckon and car back going hopefully better now :y
maddog21 care got fixed in garage 30 mins
« Last Edit: 01 July 2013, 20:35:25 by brian36 »
symes
  • oxford
    • R reg 940 volvo
« Reply #18 on: 01 July 2013, 20:38:37 »
glad its done :y :y should get another --spare--I know several v6 owners on here keep a spare handy-they go at anytime :'(
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #19 on: 03 July 2013, 10:18:35 »
now then
so got new crank shaft sensor fitted and that has taken 0300 off but as low on fuel went to morrisons and put in some fuel although i am not sure can this be related ? i have now code 0330 knock sensor bank 1 fault, this i did have a while back but not recently but have been using shell fuel,so can this code be back due to cheaper fuel or maybe related to crank shaft sensor your thoughts would much be appreciated
maddog21
  • East Yorkshire
    • Omega CDX 2.6 saloon
« Reply #20 on: 03 July 2013, 21:54:09 »
Bought genuine cs from Evans Halshaw, main VX dealer and you guessed it, wrong part!!!!
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #21 on: 04 July 2013, 19:19:13 »
http://www.omegaowners.com/forum/index.php?topic=96562.0 This probably doesn't apply to the 2.6. :-\
    • 530D M Sport, 330i Coupe
« Reply #22 on: 04 July 2013, 20:15:54 »
Crank Sensor.  :y
Part number: 90540743, approx. £56.00 + VAT
