Author Topic: Aircon woe  (Read 4029 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Aircon woe
« on: 28 June 2013, 16:25:22 »
Thought I'd finally got the aircon sorted at the start of the month with full recharge and new pressure valve fitted. It was running brilliantly ever since ..... until today  :'(
The blower engages, etc but the air is warm ish. Certainly not cold. The ECO button is cooler. This is the same as it was before it was 'fixed' but surely it can't be the valve or gas so soon?
I'll take it back to Vx next week but is there anything that I can physically check myself in the meantime?
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: Aircon woe
« Reply #1 on: 28 June 2013, 16:49:39 »
do the revs drop on idle when pressing the eco button to switch on the ac?  If not, not enough gas most likely
Does the bottle shaped alloy unit and alloy pipework (front of image) get cold?
« Last Edit: 28 June 2013, 16:55:37 by dbdb »
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #2 on: 28 June 2013, 16:58:05 »
Surely when Eco is illuminated aircon is off? When its turned on (ie not visible) the revs rise slightly before settling down. I'll check the evaporator when I get home  :y
dbdb
  • west london
Re: Aircon woe
« Reply #3 on: 28 June 2013, 17:10:45 »
yes sorry for confusion  eco word  lit up is ac off.  Pressing the eco button switches ac on and off. Can't remember TBH  if revs rise or fall when ac on but they noticeably change if it is all working and no change if not enough gas..
« Last Edit: 28 June 2013, 17:13:11 by dbdb »
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #4 on: 28 June 2013, 17:12:54 »
Cheers bud  ;)
I'm just arriving home. Once I'm fed I'll nip out and test the evaporator. should it take long to go cold from startup?
dbdb
  • west london
Re: Aircon woe
« Reply #5 on: 28 June 2013, 17:14:12 »
you'll know straight away if it is working, with ac on within 30 seconds it will be noticeably cold assuming you have the temp set down low. Noticeably cold as in very.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #6 on: 28 June 2013, 17:16:12 »
Much appreciated pal  :y
Should be interesting!
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #7 on: 28 June 2013, 17:38:25 »
Well the pipe work isn't cold  :-\
Ran it for a couple of minutes but it still felt warm to the touch. The lower pipe, where the pressure valve sits, was extremely hot.
Re: Aircon woe
« Reply #8 on: 28 June 2013, 17:39:37 »
Check if compressor spins when AC is activated
Re: Aircon woe
« Reply #9 on: 28 June 2013, 17:44:42 »
If the gas is gone I don't think it will spin anyway ?
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #10 on: 28 June 2013, 17:46:18 »
Sorry rob, how do I do that?
Re: Aircon woe
« Reply #11 on: 28 June 2013, 17:47:57 »
According to Jonny
so that implies comp should be spinning, but agree with you Albs, no gas, no spin.
Would have thought dye would have been used with the re-gas though ???
Re: Aircon woe
« Reply #12 on: 28 June 2013, 17:49:21 »
Engine idling with AC off, the front part of the compressor will be static, AC on will spin if gas pressure is sufficient
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Aircon woe
« Reply #13 on: 28 June 2013, 18:02:33 »
It's spinning as suggested  :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Aircon woe
« Reply #14 on: 28 June 2013, 18:05:01 »
Sorry to hijack  :-[ .. But when i turn the air con on the 3.2 i hear a click and revs go down and then level off again .. 2.2 doesn't do this and i know there's a fast leak somewhere on the 2.2 never bothered to get it fixed..
