Author Topic: convert headlights  (Read 2038 times)
brian36
  • Milton Keynes
  • 2.6 mv6
convert headlights
« on: 29 June 2013, 09:04:30 »
hi can i ask? can you use headlights from a other miggy and convert them to hid for my mv6?
martin42
Re: convert headlights
« Reply #1 on: 29 June 2013, 09:19:35 »
Mv6 should be standard hids,look and see if there is a headlight beam adjustment level control by headlight switch if there isn't it has hids
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 29 June 2013, 09:26:33 »
yip i have hids but they are a mess so have chance of getting a couple new headlights but they don't have the ballast etc do other headlights have the sockets etc to plug in the ballast and extra wiring required to make them hid's thanks
martin42
« Reply #3 on: 29 June 2013, 09:33:30 »
You need to buy the correct units,due to how the beam pattern is spread etc
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #4 on: 29 June 2013, 09:38:19 »
ok thanks :y
« Reply #5 on: 29 June 2013, 09:51:28 »
If the problem with your lights is the lenses ? they can be swapped over easily enough. :y
« Reply #6 on: 29 June 2013, 10:26:52 »
You can use the lights from ANY facelift CDX/MV6/Elite/Plod :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 29 June 2013, 10:52:28 »
 swapping lenses is not difficult you just need a hair drier.
 warm the edge of the lenses up and gently prise it off.
Hoof'land storeman.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #8 on: 29 June 2013, 22:08:44 »
ok thanks to all think will get replacement lights then tidy up others for spares when have time so many thanks :y
