Author Topic: servotronic problem  (Read 3211 times)
col-mv6
  • st helens
    • silver mv6 auto
servotronic problem
« on: 29 June 2013, 19:11:54 »
here we are again ive had the mig on a diagnostic (not tech 2) and it said speed output sensor not working so changed that still no joy with the steering so next I bought a servotronic relay and spent a while to get to the location n/s kick panel area and what do I find no relay in the socket so I fit my relay and guess what still no joy with the steering should I change the pump next before even thinking about driving it off a cliff into a quarry
symes
  • oxford
    • R reg 940 volvo
Re: servotronic problem
« Reply #1 on: 29 June 2013, 19:15:23 »
disconect battery for about a minute-then try-might work
col-mv6
  • st helens
    • silver mv6 auto
« Reply #2 on: 29 June 2013, 19:20:40 »
oki doki will do that tomorrow and see what happens seems silly but it has been intermittent good and bad and all this time with no relay so how that has worked is beyond me
« Reply #3 on: 29 June 2013, 19:25:01 »
What model year?
col-mv6
  • st helens
    • silver mv6 auto
« Reply #4 on: 29 June 2013, 19:36:57 »
mv6 2.6 2001 51 plate saloon silver and very annoying lol
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 29 June 2013, 19:38:23 »
if it was very very annoying-it would be an Elite ;)
« Reply #6 on: 29 June 2013, 20:11:12 »
You sure the relay position is behind N/s kickpanel. late models (and some `01 models) had the relay behind the actual fuse carrier under steering wheel side by side with rear acc socket relay and timer delay relay.
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 29 June 2013, 20:28:12 »
its big and red-if same as my late 2000 miggy and its up behind glove box on mine and i have a holder for relay that is not fitted-will check my date---according to that-your relay is behind glove box-as you  said
col-mv6
  • st helens
    • silver mv6 auto
« Reply #8 on: 29 June 2013, 20:51:57 »
well I will look tomorrow but the wiring loom and plug are on n/s as I found when I stripped it down just no relay in the socket so ive put my relay in and it fits it only goes in one way aswell due to diff size pins so I will double check tomorra on the other side
col-mv6
  • st helens
    • silver mv6 auto
« Reply #9 on: 29 June 2013, 21:02:33 »
what sort of job is it to change the solenoid on the steering box or the box itself as it looks tight in there , also is there no way of shorting out the system to give light steering permanently
« Reply #10 on: 29 June 2013, 21:15:23 »
I presume you've checked the fuse ?
col-mv6
  • st helens
    • silver mv6 auto
« Reply #11 on: 29 June 2013, 22:24:54 »
guys at this time I couldn't resist the temptation to go and look for this other relay position and whoop whoop there it was so I took the other one out from the passenger side id fitted earlier and fitted this in the new location and first time second time third fourth and so on up to now the bloody steering is working as it should so fingers crossed its ok when I go work tomorrow thanks for all the input guys and its well being noted that you lot are worth your weight in gold for information and im so glad that I have fingertip steering again . fingers crossed this stays this way but once again thanks I love you all in a car enthusiast sort of way lmao  :y :y :y :y :y :y :y :y :D :D :D :D :D :) :) :) :) :) :) :)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #12 on: 30 June 2013, 10:06:30 »
you will always get sound advice from these guys and girls ;),as they have been through it all :y
symes
  • oxford
    • R reg 940 volvo
« Reply #13 on: 30 June 2013, 10:36:30 »
too many times :D :D :y glad you sorted mate
