shoot
Started by bored bigyin54, 29 June 2013, 19:40:22
bored bigyin54
i think i will shoot my 2.2 .its getting a pain now. just took it for a short run and it behaved like a slug going uphill but then picked up again :y :y
checked plugs for oil?  ::)
bored bigyin54
Quote from: tunnie on 29 June 2013, 19:48:30
done that wenn i changed cam gasket .dry as a bone :y
See what happens when you put a genuine part on  :P ;D
bored bigyin54
Quote from: Emd on 29 June 2013, 19:59:27
;D ;D ;D not used to clean breathers thats what  ;D ;D
Steve B
did you use torque wrench (8nm)
bored bigyin54
#6
yes done that have to go out in mornin and check plugs again :y :y got to do it in the next week .towing the van in two weeks cant have it like that  :y :y
Maybe plug lead not on tight enough or you knocked it  :-\
bored bigyin54
Quote from: Emd on 29 June 2013, 20:11:37
no plug lead  :y :y
Steve B
Did you do the job as per guide on here
Quote from: bored bigyin54 on 29 June 2013, 20:14:18
no plug lead  :y :y
Take it for italian tune up , probably just s#it in it  :-\
bored bigyin54
Quote from: bigtimecube on 29 June 2013, 20:18:50
yes .what i will do in the morning is check the plug  well again may be gasket moved  ??? ???
bored bigyin54
i think its time to get a car i dont have to work on :y :y
symes
maybe a bit of crud got pulled through fuel line-noticed that if i go to tesco's :-\
Quote from: symes on 29 June 2013, 20:59:02
Don't subscribe to those kind of theorys tbh, modern fuels are perfectly clean.
Dropped the tank on a 140k 2.5TD, perfectly clean inside, no grit no dirt, no nothing  :y
