Author Topic: Replacing brake pipes.  (Read 3114 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« on: 03 July 2013, 19:22:46 »
Anyone got any tips on replacing the front rear brake pipes without getting air in the ABS pump?
TuBy's new whipping boy.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Replacing brake pipes.
« Reply #1 on: 03 July 2013, 19:47:59 »
Crack open the pipes you are going to change then put brake pedal to the floor and hold it down while you replace the pipes,it will stop the fluid loss(other than the initial pump to floor) :y
other rides
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 03 July 2013, 19:50:45 »
+1 :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #3 on: 03 July 2013, 20:23:44 »
So you don't rate the old cling film over the reservoir cap then?
« Reply #4 on: 03 July 2013, 20:25:29 »
Always used the clingfilm method when swapping cylinders/calipers :y  As well as then capping the pipes removed with a "custom made" fitment ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 03 July 2013, 20:25:49 »
I can never get that to work---but that's me :y
chrisgixer
« Reply #6 on: 03 July 2013, 22:26:53 »
Discussed the with Andy P a while back. He rekoned no action required, just un bolt them and fit the news one, bleed, jobbed. Not done the job yet myself. Intend goodridge braided at some point.
« Reply #7 on: 03 July 2013, 22:33:09 »
I think there's a north / south translation barrier here  ;D ;D
The Captain is talking about the rigid pipes that go front to rear ....... you're talking the flexi hoses  ;) ;)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #8 on: 03 July 2013, 22:41:30 »
Indeed Andy, seems like it's going to be a cut and join job when himself works out how to use the portable flaring tool from work.
« Reply #9 on: 03 July 2013, 22:47:02 »
I have some small bore pipe benders somewhere if you need/want to use them.  :y
chrisgixer
« Reply #10 on: 03 July 2013, 22:47:25 »
Andy can you translate ? I got the cut and join bit. :-\
I may have cause to move the abs pump, and was wondering if joining was acceptable tbh. :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #11 on: 04 July 2013, 01:29:19 »
Seems it's a common enough repair technique Chris and acceptable to the MOT man as they do it at the garage TG works at.
« Reply #12 on: 04 July 2013, 09:27:43 »
I would just seal up the reservoir cap and crack on. I doubt the fluid will move much as the ports on the ABS block all point upwards.
henryd
  • west cornwall
« Reply #13 on: 04 July 2013, 11:05:39 »
Me neither,pedal wedged to floor always works though :y :y
other rides
