One careful owner
Started by omega3000, 04 July 2013, 15:23:02
Quote from: symes on 04 July 2013, 16:55:20
Quote from: Emd on 04 July 2013, 16:36:41
Quote from: symes on 04 July 2013, 16:03:29
Quote from: Emd on 04 July 2013, 15:58:54
Quote from: OmegaMan2.2 on 04 July 2013, 15:50:15
Very nice example and cheap  :o That the type you after or with a different engine ?
2.2 is ok , just like the one we took back from auction . Its on the wish list and has been for many yrs .. :y
thats best one---fit v8 shox and springs and larger diameter roll bar--out handle miggy no sweat :y
;D :-\
I think i would drive it sedately , put my flat cap on and go for a nice sunday cruise  :D ;)
yep easy to do as rover is probably only 4 door saloon that is 50/50 weight distribution-most are 65/45 :y
Most of the M3's M5's are 50/50, as were quite a lot of cars I thought  :-\
symes
we talking classics mate :y :y
symes
Quote from: symes on 04 July 2013, 17:18:12
http://www.youtube.com/watch?v=DYDD3nzezOY
Enjoyed that  :y The production line didnt seem to be hard pushed  ;D More laid back attitude and got the job done right without the interference of health&safety  >:(
symes
BazaJT
It's the "skeleton"that's important all outer panels[including the roof] just bolt on to this.On the 4cylinder engine the side plates can rot through giving water leaks.Had a 2200SC myself once,no ball of fire to drive but comfy and reasonably economical too.Boot space is rubbish unless you go for the boot mounted spare wheel option.Rear seat definitely shaped for just two people,no bench  seat in a P6.
symes
Quote from: BazaJT on 04 July 2013, 18:45:12
really  :o :o only boot i know of where you can lay spare wheel flat or upright--in mine got 2 rear wheels---drags
Side plates  ??? Please explain what the side plates are  :-\
Quote from: tunnie on 04 July 2013, 16:59:03
;D :-\
They are as is the Omega.
I feel a challenge coming on,  ;D ;D
symes
Quote from: Emd on 05 July 2013, 10:57:58
the 2000/2200 four cylinder engine had steel plates on sides of engine block--which meant all casting sand removed-also as it form engine block--coould leak --after 20yrs or so---easy to change though :y
