Author Topic: V6 cats  (Read 2484 times)
smartrs
  • out in the sticks
V6 cats
« on: 05 July 2013, 21:53:05 »
How do you know when your cats are on there way out ?? My car seems to be down on power sometimes and the exhaust note sounds slightly different as if its slightly struggling then other times can be fine could this be cats or any thing else to do with the exhaust and I have a whiling problem which sounds exhaust area too , it's a 99 estate
Re: V6 cats
« Reply #1 on: 05 July 2013, 21:58:01 »
Blocked back box?
smartrs
  • out in the sticks
Re: V6 cats
« Reply #2 on: 05 July 2013, 21:59:06 »
May be how could you tell ?? And here's hoping that's all lol
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: V6 cats
« Reply #3 on: 05 July 2013, 22:12:40 »
noel
  • frome somerset
Re: V6 cats
« Reply #4 on: 05 July 2013, 22:15:00 »
check end of tail pipe to see if its spilling its guts out (looks like fibreglass)
chrisgixer
Re: V6 cats
« Reply #5 on: 06 July 2013, 08:40:16 »
Remove a lambda sensor and fit a pressure gauge. (If blocked badly enough, it blows the pipe off anyway, so don't know what the readings should be ;D )
Compare the exit pressure with a hand over the exhaust, with another car the same at a set rpm.
Borescope up the exhaust.
« Last Edit: 06 July 2013, 08:47:29 by chrisgixer »
chrisgixer
Re: V6 cats
« Reply #6 on: 06 July 2013, 08:46:53 »
Cats structure of the honeycomb don't usually collapse on omega. Its the efficiency of cleaning gases that's important. 3.0 cats are pretty bomb proof, unless there's a engine management issue where Unburnt fuel is sent down the exhaust.
Blocked exhaust (back or middle boxes) or an engine management problem seem more likely.
smartrs
  • out in the sticks
Re: V6 cats
« Reply #7 on: 07 July 2013, 14:37:11 »
Took the car into the local garage yesterday as the whisling was quite bad and there on tick over they had a listeren around the engine bay and then had it up on the ramp and it was really loud by the right hand cat so seems that this could be the cause of the intermintant whistle and slight lack of power  ???
Page created in 0.01 seconds with 14 queries.
