Author Topic: Omega engine fit  (Read 5390 times)
totalomega
    • omega&more
Omega engine fit
« on: 09 July 2013, 12:10:03 »
Hi all,new to the forum
Im just wondering what engine will fit in my omega easily.do cavaliers etc fit?currently there is a 2ltr ecotech in it but its on the way out,so im thinking about upgrading? any help appreciated
Thanks
Re: Omega engine fit
« Reply #1 on: 09 July 2013, 12:16:48 »
Given the low price of Omega's is it not easier and cheaper to buy one with engine already fitted?
Its going to be a lot of work to retro fit a V6, so not really worth it. If you are going to fit another engine my choice would be to shoe horn a LS1 V8 in.  :)
totalomega
    • omega&more
« Reply #2 on: 09 July 2013, 12:21:59 »
im in ireland and cant see anything that cheap so far. theres test on the car too until march so thats why i thought stick sumtin good in if it fits/works easy
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 09 July 2013, 12:25:31 »
Hi. Welcome to the forum. :y
Might be better to fix the existing problem(s).
There is a tremendous amount of knowledge on the forum across the different models. If you do need to bin your engine then it is likely that one of the breakers on the forum has a suitable "same" 2.0 engine.
« Reply #4 on: 09 July 2013, 13:07:06 »
Replace with the same engien type is the easiest, same power plant (minor differences on ancillaries which are easily swapped) used in the Astra and Vectra.
Or maybe a LET engine?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #5 on: 09 July 2013, 13:39:38 »
Very tuneable for not a lot of dosh  :)
totalomega
    • omega&more
« Reply #6 on: 09 July 2013, 13:58:15 »
whats that now? sorry as i said im new  :)
andyc
  • Norfolk
« Reply #7 on: 09 July 2013, 14:15:21 »
LET is the engine code for the 16v Red Top Turbo engine found in the old Calibra/Cavailer. If you fine a cheap one of these budget for a complete re-build as 90% of these and normal red top will have been thrashed to within a inch of going bang
The block for an Ecotech Vectra, astra is the sames block just use the Omega manifolds etc
Cheers
Andy
Thetford. Norfolk
« Reply #8 on: 09 July 2013, 14:26:39 »
or the z20let which are newer and more plentiful
totalomega
    • omega&more
« Reply #9 on: 09 July 2013, 14:45:23 »
that sounds good andy,thanks. i actually might no where theres one!
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #10 on: 09 July 2013, 16:37:15 »
I have a Swindon racing V6 in mine - you can have that for £500 with the rest of the car still attached!  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 09 July 2013, 16:46:05 »
What's the output on that ?
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #12 on: 09 July 2013, 16:50:11 »
TBH I havent rolling roaded it as yet.
The spec sheet from Swindon says 206BHP but I've fitted 3.2 manifolds and had it ported a bit since then.
My guess is about 220.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 09 July 2013, 17:10:31 »
That's a 2.5 right ?
Does it use a stand alone ecu ?
Sorry to the op for the thread drift  :)
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #14 on: 09 July 2013, 19:23:07 »
It's on the original ECU so there's room for more gains yet.
Nuff said on this thread though - I have a for sale thread for the car so any chat about it can go there.
Sorry for the thread-jack   :P
Page created in 0.031 seconds with 16 queries.
