Pages: 1 [2] 3  All   Go Down
Author Topic: Airbag fuse  (Read 9773 times)
Re: Airbag fuse
« Reply #15 on: 10 July 2013, 15:56:26 »
So, front seats changed and it's complaining about both side airbags?
Sounds to me like the seats were from an earlier model without side airbags.
Re: Airbag fuse
« Reply #16 on: 10 July 2013, 16:39:22 »
Previous thread
The seats were from my cdx this car is a cd, both face lift.  the light was on before I changed the seats & still on now. will ask the guy what reader he used to pull the codes.
http://www.omegaowners.com/forum/index.php?topic=114516.msg1446648#msg1446648
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Re: Airbag fuse
« Reply #17 on: 10 July 2013, 17:00:06 »
Cheaper to buy a new car than pay vauxhall to fix it :'(
Re: Airbag fuse
« Reply #18 on: 10 July 2013, 17:01:27 »
PM TheBoy, very reasonable Tech2 rates & just down the A43 in Brackley  :y
Re: Airbag fuse
« Reply #19 on: 10 July 2013, 18:05:44 »
Put the correct seats back in, then turn light out.
If you must have leather (why? cold in winter, hot in summer), get the right ones :)
I'm guessing its probably got the wrong pretensioners as well, so little chance of playing silly beggers.
Re: Airbag fuse
« Reply #20 on: 10 July 2013, 18:57:21 »
Previous thread
OK, if it's got compatible seats then best case the ECU will still require a reset with a tech 2 to turn the light off. If the problem was in the old seat, then you're in luck. If not, it won't solve the problem, but will give you more pointers as to what the problem might be.
Omega 37
  • Northampton
Re: Airbag fuse
« Reply #21 on: 10 July 2013, 21:43:04 »
Tech 2 can't reset it
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Airbag fuse
« Reply #22 on: 10 July 2013, 21:52:39 »
I'm a little confused.
The original seats had airbags?  The replacement seats have airbags?
If the original seats DIDNT have airbags, why would you have a problem?  If they did and there was a fault with them, the replacement seats and a reset would kill the light, UNLESS there was a problem with the replacement seats......
Start from the beginning, middle in the middle and end at the end.  What exactly have you done and where is the problem?
Re: Airbag fuse
« Reply #23 on: 10 July 2013, 21:55:24 »
Whose Tech 2?
Re: Airbag fuse
« Reply #24 on: 10 July 2013, 23:01:38 »
A tech 2 will show you which circuit it's complaining about, and also allow you to check the resistances.. if the operator knows how. ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Airbag fuse
« Reply #25 on: 12 July 2013, 11:05:57 »
Important to say "proper" tech2 and not a computer PC wannabee bit of kit  :-X
Radio & Decoding Technician
www.dndservices.co.uk
Re: Airbag fuse
« Reply #26 on: 12 July 2013, 11:08:42 »
Agreed, said kit wants to have a LONG cable on it if I'm going to connect it to the airbag ECU. ;)
Re: Airbag fuse
« Reply #27 on: 13 July 2013, 10:21:12 »
Where is your sense of adventure, Mr Wood?
Re: Airbag fuse
« Reply #28 on: 13 July 2013, 10:22:35 »
Actually, given recent explosive events, I'm probably the last person who should be making wise cracks. Sorry Kev, was purely a flippant, non-serious remark  :-[
Omega 37
  • Northampton
Re: Airbag fuse
« Reply #29 on: 15 July 2013, 11:03:55 »
Not sure about the tech 2. it looked like the boy's one.
The 39 year old firenza passed  ;D Mig failed on 2 broken rear springs  :'( thought the handling was a bit duff lol
No advisory's about the lack of airbag light !!!!!!!!!
I had a w reg cdx with leather the engine blew so i bought my fathers y reg cd with knackered drivers seat. The airbag light was on in the cd. Both cars have airbags in the seats & the plugs were the same.
I swapped the interior's over but the light was still on. tried to reset with the tech2 but no joy  :'(
« Last Edit: 15 July 2013, 11:05:28 by Omega 37 »
Pages: 1 [2] 3  All   Go Up
