Author Topic: PDF file  (Read 3341 times)
Re: PDF file
« Reply #15 on: 10 July 2013, 18:21:18 »
I reckon item 22?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: PDF file
« Reply #16 on: 10 July 2013, 18:26:08 »
However, thanks to the reminder by Tunnie and other recent posts, I will order an HBV to carry in the boot along with my crank sensor for the 3.2. I guess I better get one for the TD as well. :y
Shackeng
  • Ramsbury
Re: PDF file
« Reply #17 on: 10 July 2013, 18:27:03 »
I reckon item 22?
Thanks Jaime. Are the 'o' rings on there as well? I note it only shows one #22. :-\
« Last Edit: 10 July 2013, 18:28:50 by Shackeng »
Re: PDF file
« Reply #18 on: 10 July 2013, 18:50:27 »
EPC says 2 x 22 are required.
O rings are different I believe, and I suspect on the condensor screen - cant check at mo...
Re: PDF file
« Reply #19 on: 10 July 2013, 19:02:11 »
Thanks Byron.
Neither I nor my dealer can identify the AC compressor Dowty seals, and condenser 'o' rings. If someone could point them out on the pic, I would be grateful. :y Although from what Tunnie says, this is probably the wrong diagram. :-\
90381758
Size  9.3 x 2.4
Re: PDF file
« Reply #20 on: 10 July 2013, 19:19:03 »
These aren`t they :-\
Only part # I can find is 15-2722 (American site) but GM should be able to cross ref.
Manufacturer: ACDELCO GM ORIGINAL EQUIPMENT
Part Number: 15-2722
Description: A/C Gasket
28mm Od X 15.5mm Id ; INCLS TWO 5/8 SEALS ; 2 Per Veh
« Last Edit: 10 July 2013, 19:25:24 by RobG »
Shackeng
  • Ramsbury
Re: PDF file
« Reply #21 on: 10 July 2013, 19:33:35 »
Thanks very much Rob.  :y :y :y
Re: PDF file
« Reply #22 on: 10 July 2013, 19:45:56 »
Suppose I`ll have to think about using "shopkeeper" as my username ::) ::)
Page created in 0.021 seconds with 16 queries.
