Author Topic: 2.2 dti estate wont start if parked facing uphill.  (Read 2990 times)
mmcg
« on: 10 July 2013, 18:03:12 »
Happened twice recently any ideas.
taitinson
  • Sunny Cornwall
    • 03 2.6 CDX Estate
Re: 2.2 dti estate wont start if parked facing uphill.
« Reply #1 on: 10 July 2013, 18:08:40 »
I may be wrong but i'm sure i've read on here before of the same problem, which if i remember correctly happens on estates if low on fuel and parked up hill, someone will be along to confirm or deny shortly i'm sure
martin42
« Reply #2 on: 10 July 2013, 18:11:33 »
Fuel leak of pipes might need replacing
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 10 July 2013, 18:14:54 »
Can occur with the in-tank pump assembly on the 2.5TD. Another story.
Don't think that the 2.2DTi has an in-tank pump, so I'd change ALL the leak-off pipes to start with. ;)
waspy
« Reply #4 on: 10 July 2013, 18:28:16 »
I'll guarantee it'll be the injector seals, possibly the pump, but my money's on the seals  :y
mmcg
« Reply #5 on: 10 July 2013, 22:32:16 »
Leaving for Billing tomorrow , it would act up now.
« Reply #6 on: 10 July 2013, 22:35:46 »
That is certainly the case with petrol versions. No idea about diesels though. :y
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 10 July 2013, 22:46:45 »
+1  :y
mmcg
« Reply #8 on: 10 July 2013, 22:59:02 »
Will get at the injector seals and leak off pipes when [if] we make it home again. :y
« Reply #9 on: 10 July 2013, 23:15:05 »
Put 3 gallons in it and report back ::)
mmcg
« Reply #10 on: 10 July 2013, 23:44:10 »
Put in 92 euros to day range read 642 miles
« Reply #11 on: 11 July 2013, 19:14:36 »
Did it start ::)
« Reply #12 on: 12 July 2013, 08:34:10 »
Fit a priming bulb with non return valve to the diesel pipe work as the VP44 pump is a lift pump free self priming injector pump.
The issue they have is not the pump (its pretty much bullet proof), its the electronic module which controls the solenoids and contains the calibration info. This has a couple of 'glob n gloop' power transistors in it which are cooled by the incoming fuel, no fuel and they cook.
So when the pipes and seals get a bit tired and air gets in or when changing the fuel filter, you risk screwing the electronics.
mmcg
« Reply #13 on: 16 July 2013, 21:39:53 »
Made it home from Billing last evening, 803 miles  used 73.90 ltrs  cost 112 euros.  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #14 on: 17 July 2013, 15:40:51 »
49.4 mpg :D :D :o
other rides
