Author Topic: Help required with 3.2 AirCon condenser removal  (Read 4608 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 12 July 2013, 16:28:40 »
Hi guys, having got my Dowty seals and 'o' rings, I've just started stripping the 3.2 to remove the condenser, and I see a third small radiator in between the condenser and main rad. Am I correct that this is the ATF cooler? It does not appear in the how to on the 3.0. If so, I assume this will also have to come out before the condenser. any advice on this? :-\ :-\ :-\ :y
Re: Help required with 3.2 AirCon condenser removal
« Reply #1 on: 12 July 2013, 16:32:36 »
ATF cooler Chris, bolted at the 4 corners to main rad. Remove as one unit with radiator but just be careful when undoing the ATF pipe block at cooler end that you retain the rubber "O" rings. Block with "O" rings highlighted
« Last Edit: 12 July 2013, 16:35:48 by RobG »
Shackeng
  • Ramsbury
« Reply #2 on: 12 July 2013, 16:35:43 »
Thanks Rob. I am impressed with your rapid reply!!!
Cheers Mate. :y :y :y
« Reply #3 on: 12 July 2013, 16:36:13 »
Edited with a pic
« Reply #4 on: 12 July 2013, 16:41:15 »
Edited with a pic
as it should have been in the first place ..........  ;)  ;)  ;)
« Reply #5 on: 12 July 2013, 16:41:39 »
Edited with a pic
:P
Shackeng
  • Ramsbury
« Reply #6 on: 12 July 2013, 16:44:41 »
Edited with a pic
It was already good, but now even better :y
I presume the fan attached to the main rad comes out with it? :-\
« Reply #7 on: 12 July 2013, 17:16:59 »
Edited with a pic
Easier that way Chris
Shackeng
  • Ramsbury
« Reply #8 on: 12 July 2013, 17:20:13 »
Thanks Rob :y :y :y
« Reply #9 on: 12 July 2013, 17:21:03 »
Don`t forget the thermo switch connectors :)
Shackeng
  • Ramsbury
« Reply #10 on: 12 July 2013, 17:58:33 »
Already done, but thanks for heads up, just struggling to access the clip on the bottom rad  pipe connection at the moment :y :y :y
Edit: Now got it off. ::)
« Last Edit: 12 July 2013, 18:12:31 by Shackeng »
« Reply #11 on: 12 July 2013, 22:59:39 »
Start waggling ;)
Shackeng
  • Ramsbury
« Reply #12 on: 13 July 2013, 08:31:13 »
Now waggled! The clip was just slightly in the wrong place to access with any of my various clip removers, but all OK now thanks. Just going out for round 2, as I only had a couple of hours on it yesterday. :y :y :y
ted_one
« Reply #13 on: 13 July 2013, 09:22:01 »
Having followed this thread with interest as I had planned to do all three of mine as the condensers are all original and are not holding the gas for very long....BUT....having seen how much patience is going to be needed to do the job then as I  have had a patience bypass it looks like they will be heading to the local A/C place in Slough,had a quote for £800 for each car.
Seems a lot but hey ho it's got to be worth it not to be involved ::)
« Reply #14 on: 13 July 2013, 09:23:42 »
At that price I'd definitely do it myself & then get the specialist to fill the system.  :y
