Pages: [1] 2 3  All   Go Down
Author Topic: Recommended 3.2 Radiator supplier?  (Read 5296 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 13 July 2013, 09:42:30 »
As I now have the rad out as part of my AC compressor and condenser swap, and as the rad has some bashed in fins, and is 12 years old, I shall replace it to save more work later. Can anyone recommend a good quality pattern supplier for these?
TIA :y :y :y
« Last Edit: 13 July 2013, 09:47:46 by RobG »
Shackeng
  • Ramsbury
Re: Recommended 3.2 Radiator supplier?
« Reply #3 on: 13 July 2013, 09:49:30 »
Yep, used them, very good quality Chris
Shackeng
  • Ramsbury
« Reply #4 on: 13 July 2013, 09:52:30 »
Thanks again Rob. Ordering now. :y :y :y
« Reply #5 on: 13 July 2013, 10:35:06 »
Not used their Omega ones, but I got one for the little Rover from there, looked good enough quality.
Can't comment on longevity, as that car has long gone to make Beanz tins
jb
  • bucks
    • 3.2 Elite
« Reply #6 on: 13 July 2013, 21:20:20 »
I have used them numerous times,all good quality.
« Reply #7 on: 13 July 2013, 22:46:20 »
I have had two Omega radiators from them - quick delivery, good quality, and no subsequent issues :y
Shackeng
  • Ramsbury
« Reply #8 on: 14 July 2013, 11:24:49 »
Got one on order now, :y :y :y
« Reply #9 on: 14 July 2013, 22:11:31 »
Late to this as been away .... make sure you get the right one !!!! When I had my problems with radiator they insisted that they knew which one I needed .. BUT THEY WERE WRONG !!! - as were several other places .. :(
You need the radiator with the mounting points for the external ATF cooler .. they might try and tell you the ATF cooler is internal ...also, the top "lip" is different and that is, in part, how the ATF cooler is located.
Due to severe time constraints I got one from VX .. expensive but it fitted perfectly
Shackeng
  • Ramsbury
« Reply #10 on: 14 July 2013, 22:15:30 »
Cheers Nige, I'll ring them AM. :y
Shackeng
  • Ramsbury
« Reply #11 on: 15 July 2013, 15:29:38 »
Thanks to Entwood I checked with Car Cool today and the rad they were going to send me had an integral oil cooler. Clearly I don't want this as I have a separate ATF cooler to fit on the front of the rad. Looking at other pattern suppliers, ECP, and CarParts4Less and another who want £364, they all seem to do the same type with in-built ATF cooler. VX is £234 +VAT so I would be grateful if someone knows of a supplier who supply the correct type.  :y :y :y
Shackeng
  • Ramsbury
« Reply #12 on: 15 July 2013, 15:38:38 »
Just spoken with CAF, and they can supply a Hella for £105.99 +VAT without the integral cooler. Any experience of Hella rads? :-\
Shackeng
  • Ramsbury
« Reply #13 on: 15 July 2013, 18:50:39 »
Apologies for the bump, Has anyone used Hella Rads?
« Reply #14 on: 15 July 2013, 18:59:37 »
In partnership with German firm "Behr" who have over 100 years manufacturing exp. of vehicle rads. Should be OK Chris
Pages: [1] 2 3  All   Go Up
