Author Topic: changing V6 starter - cannot get top bolt in  (Read 1880 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 13 July 2013, 10:51:05 »
I am following GastronomicKleptomaniac's excellent maintenance guide. Fitting new starter, he says 'Wiggle the starter into place, refit top bolt by a few threads' and here I am stuck. I am working from above, I seem to be able to get the starter into place, though it is able to rotate about 60 degrees, then I strive to fit the top bolt. It is difficult to locate the point where the hole is aligned with the thread, and impossible to turn the bolt when i think it is in the right place.
What am I doing wrong?
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: changing V6 starter - cannot get top bolt in
« Reply #1 on: 13 July 2013, 11:40:13 »
I did it from below Terry, took half an hour only.  :y  one jack and one axle stand I used there, the stand to the chassis and the jack to the engine, remove the coolant bottle having a bit more place to work easily and come on! I was removing the engine mount then the starter. A little bit I had to lift on the engine when removing the mount but was no more disturbing circumstance. Good luck !  :y
Laszlo
C20NE - X25XE
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 13 July 2013, 14:09:57 »
Well done! I have changed four starters on 2 litre Omegas, but I could see what I was doing then. This job seems to be all done by touch.
Which bolt did you put in first, top or bottom?
Laszlo
Johnny English
  • Hungary
« Reply #3 on: 13 July 2013, 20:24:59 »
Laszlo
I can't remember surely as there was so much place that it was no matter mate. IIRW the top one was the first though...
C20NE - X25XE
chrisgixer
« Reply #4 on: 13 July 2013, 20:49:26 »
Having done an alternator recently, I would have presumed to go from underneath. Would that help access? :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 13 July 2013, 21:26:52 »
Thanks for help, Johnny and Chris. I finally got the bottom bolt in, working from below, by propping the starter in with a piece of timber and turning it round poking an allen key through the bottom hole in the starter until I located the thread in the flywheel housing. Then I screwed in bottom bolt, then top bolt went straight in.
I found it a difficult job. I take off my hat to Johnny, doing it in half an hour.
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #6 on: 14 July 2013, 09:19:47 »
I must have been lucky with mine then  ;D
« Reply #7 on: 14 July 2013, 10:17:20 »
[/highlight]
Ah, but you've got Surgeons fingers GK :y
Or should that be pickpockets fingers :-\ ;D ;D ;)
