Author Topic: 3.2 Crank sensor.  (Read 3655 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
3.2 Crank sensor.
« on: 13 July 2013, 19:10:36 »
As I've got all the front gubbins out while changing the compressor and condenser, it occurred to me that I could fit my spare crank sensor in place alongside the existing serviceable one, using the umbrella principle that if I have one in place, it will never fail.
Any thoughts? :-\
Re: 3.2 Crank sensor.
« Reply #1 on: 13 July 2013, 19:21:09 »
If you do that Chris, sod`s law your original won`t fail ;D
« Reply #2 on: 13 July 2013, 19:29:35 »
.. and when it does, the spare will have perished due to the heat of the engine bay. ;)
chrisgixer
« Reply #3 on: 13 July 2013, 19:47:45 »
I wouldn't fit it until needed. Personally.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 13 July 2013, 21:11:43 »
Just give it a good talking to whilst your down there. ;)
Shackeng
  • Ramsbury
« Reply #5 on: 13 July 2013, 21:32:18 »
I was working on the idea that the original is designed to cope with the same heat. ??? :-\
« Reply #6 on: 14 July 2013, 10:37:55 »
It is, but for how long? ;)
Shackeng
  • Ramsbury
« Reply #7 on: 14 July 2013, 11:19:40 »
Ah, are you implying that it is the heat that causes them to fail? I thought that it was just electrickery again. :-\
« Reply #8 on: 14 July 2013, 12:18:22 »
The wiring runs very close to the exhaust manifold. Its wrapped in a heat shield,which isn't much more than a piece of silver paper.
Over time the heat breaks down the wiring internally until it fails altogether. Hence the advice to route it differently when replacing. :y
« Reply #9 on: 14 July 2013, 12:24:44 »
Wouldn`t it be prudent to use something like this when fitting a replacement then ???
http://www.ebay.co.uk/itm/20mm-High-Temperature-Heat-Resistant-Kapton-BGA-Tape-Polyimide-/111108471420?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%26pmod%3D290887988653%26ps%3D54
chrisgixer
« Reply #10 on: 14 July 2013, 12:40:15 »
Unless the new sensor is faulty, any v engine owner will only need to fit one sensor per cars life. As said, once the sensor is re routed, it sits in a considerably cooler environment.
Shackeng
  • Ramsbury
« Reply #11 on: 14 July 2013, 12:46:41 »
OK, so how about I fit the spare in place but using the new recommended routeing? Then if it fails while I am traveling away or abroad, which is when I use the 3.2 the most, it will just need connecting at each end. :-\ :-\ :-\
chrisgixer
« Reply #12 on: 14 July 2013, 12:52:26 »
Its not routing it that's awkward though. At roadside, you still need to jack the car, get under there lieing on the ground to unbolt the sensors end, fit the new one, and bolt it back in. The rest, that your proposing is a two minute easy job by comparison. Your also introducing the possibility of debris, rust, corrosion in the plug end. Or possible damage to the sensor end as it will need to be tied up somewhere.
Your sensor, but not worth the risk IMO. But each to their own.
Keep it safe in the box, or there's a chance of two non working sensors when you really need it.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #13 on: 14 July 2013, 12:54:06 »
I agree with Chris,I wouldn't fit it till needed as following alternative routing makes it easy to fit anyway :y
other rides
chrisgixer
« Reply #14 on: 14 July 2013, 12:55:05 »
If your considering partially fitting. IMO it would be better to fit it new completely, as the new routing, job jobbed.
