My mate's new PAS pump fitted... but can we repair the old one....
Started by Webby the Bear, 16 July 2013, 14:39:44
Webby the Bear
Afternoon fellas, hope you're well.
I fitted my mates new PAS pump but i'm now stuck with his old one. And being the inquisitive chap I am I thought i'd take it apart :)
Those little rectangle pieces of metal are the bearings that fell straight out of the bearing holder (??) that sits next to it in the photo. if I can get this sucker going (my mate kindly said I can refit on his car to test it out) then I'll have learned some stuff and perhaps make some dosh on a resell :):):)
so.
shall I grease these up and refit? theres no obvious signs of damage or wear? im thinking, grease, refit and test. what say you? :)
ps this is the pas pump off a 2004 Hyundai coupe 2L SE
:y :y :y
RIP Paul Lovejoy
henryd
Those little plates are part of the impeller of the pump Webby :y
other rides
Webby the Bear
Quote from: henryd on 16 July 2013, 14:42:36
Aha! thanks mate. I assumed they were bearings..... so if the bearings have gone where do I find them?
ps, this failed bearing/s was the diagnosis of a mechanic, not just me guessing  :y
RIP Paul Lovejoy
Not much goes wrong on the PAS pumps, its normaly a seal or a bit of crudd on the pressure control line.
The metal parts form part of the impeller assembly which actualy pumps the fluid.
That looks like a Saginaw pump to me
Webby the Bear
it was screeching when you got to either full lock. it was physically stopping the belt and its that rubbing that was causing it
RIP Paul Lovejoy
And he diagnosed bearings pmsl......oh dear
Pressure relief valve I would say
Webby the Bear
thanks mark. I was very careful not to advise as I didn't know what the problem was. so this is what he was told  :y
is the PRV on the rack itself? :)
RIP Paul Lovejoy
Its normaly on the pump and is often under one of the bolts that is on the side of the pump body
Webby the Bear
Thanks mark. theres a big bolt that has two washers, has a hole in it and fits one of the hoses to the pump.... is this it?
RIP Paul Lovejoy
Webby the Bear
RIP Paul Lovejoy
symes
Quote from: symes on 20 July 2013, 18:40:40
The vanesd wear down=not so good as a pump then :-\
Never seen it happen on a modern system to be honest and there are not signs of scratching or witness marks on the rotor outer in the pic.
Every time I have stripped one its been gunk in the system be it in the pressure relief valve or the pressure regulating part.
