Author Topic: 2.0 CDX Engine removal & Refitting  (Read 5247 times)
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« on: 16 July 2013, 22:20:21 »
Well after removing the air filter, cleaning the breather pipes my 2.0 CDX is still putting out blue smoke when hot, so it now appears as if it is my first fear of worn rings/engine wear, I have sourced another 2.0 engine which I am picking up tomorrow evening, does anybody know how difficult removing and fitting the new engine will be ?, and would it be easier to remove with the auto gearbox still attached to the engine ?, if anyone has done this job before I would really appreciate any advice..
Many thanks
Terry
Omega's beat any fancy limousine for comfort/luxury everytime
mick-1975
  • nottingham
Re: 2.0 CDX Engine removal & Refitting
« Reply #1 on: 17 July 2013, 15:01:36 »
To be honest not that hard but I have done a few in the past . First omega I did I labelled each connector up from number 1 on masking tape just to make it easier when 're fitting . Just move the wiring loom to one side uf u leave gearbox in car . Good luck plenty of help on here for you .
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« Reply #2 on: 18 July 2013, 23:25:04 »
Thanks Mick.. appreciate your comments
« Reply #3 on: 18 July 2013, 23:34:40 »
Four pot engine not that hard to remove.As said,label things,but also take pics which you can refer to if you get stuck.
Probably easier to lift the engine/box out together imo. :y
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« Reply #4 on: 27 July 2013, 20:00:51 »
Hello everyone, the latest on my 2.0 CDXi Omega - Unfortunately it is not good news  :( , last week I picked up a 85,000 mile replacement 2.0i engine, it came out of a manual Vectra but the Vauxhall fitter confirmed after checking that the engine details were the same that it would fit in an auto Omega, so with that information I bought the engine, today we begun the job of removing my old engine, once removed we begun fitting the ancillaries to the new engine, that was when we hit major problems, the sump was totally different and would not fit in my rear wheel drive Omega engine bay, so we removed the sump on both engines, we were met with horror :'( , the crank etc was different, so here we were with 2 engines in bits, my one with it's smoking engine and the new one that wouldn't fit in my car.... So now my poor old Omega is now sitting down the side of a garage with no chance of running any time soon (I have spoken with Steve the spares fella and although he was his usual helpful self he did not have a 2.0 litre engine that would fit into an automatic W registered (2000) 2.0 litre). So here I am asking "does anybody know where I can find myself a low mileage 2.0 Litre engine that will go straight into my Omega ?
« Reply #5 on: 28 July 2013, 10:53:37 »
Drop a 2.2 in and transfer the 2.0 ancillaries (sensors, camcover etc)
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« Reply #6 on: 28 July 2013, 16:06:27 »
Thanks Rob - Will the 2.2 run okay with all my original 2.0 ancillaries, ECU on board computer etc ?
« Reply #7 on: 28 July 2013, 17:46:18 »
Yep
bored bigyin54
  • south wales
    • black beast
« Reply #8 on: 28 July 2013, 18:47:07 »
dont know how far you are from newport but there is a place called vauxplus who do engines . if you want i can get you their number later :y :y
« Reply #9 on: 28 July 2013, 19:01:53 »
Well his profile does say Suffolk  ::) - So quite a way  ::)
Yep
Yup I'd go 2.2 as well, little bit more torque. I'd keep an eye out for breakers here, then you know if the engine has come from a working donor :)
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« Reply #10 on: 28 July 2013, 23:24:52 »
Thanks for this, Do you know if they will deliver ? as Newport is a long long way from where I am.. If not then if you would be so kind as to give me their contact number and I might be able to work something out with them..
Thanks for your help
Terry
OmegaTel57
  • Suffolk
    • Omega 2.0 CDXi
« Reply #11 on: 28 July 2013, 23:27:59 »
Yep
Thanks Tunnie, I'll keep on looking, would you mind letting me know if you hear of an engine that becomes available, just don't want my car to sit there and rot at the rear of a garage  :(
Thanks for your help & advice
Terry
bored bigyin54
  • south wales
    • black beast
« Reply #12 on: 29 July 2013, 16:13:48 »
Terry
i think they do deliver have to look for the number . i will get back to you :y
« Reply #13 on: 29 July 2013, 16:18:49 »
http://www.vauxplus.com/
Western Indust Estate, Ponthir Rd, Newport, Gwent NP18 3NW
Tel: 01633 420 333
bored bigyin54
  • south wales
    • black beast
« Reply #14 on: 30 July 2013, 07:07:06 »
Tel: 01633 420 333
thats the one . thanks tunnie :y :y
