Author Topic: advice needed please  (Read 1189 times)
brian36
  • Milton Keynes
  • 2.6 mv6
« on: 17 July 2013, 16:31:14 »
so still having problems with my 2.6 mv6 f/l
have changed crank shaft sensor and dis pack 1-3-5 was showing knock sensor fault now showing p0300 random  multiple misfire
what next? car seems  slower than norm and when revving do get odd splutter. :'(
Re: advice needed please
« Reply #1 on: 17 July 2013, 16:36:25 »
is P0300 the only code?
Plugs clean and dry?
Also have you tried unplugging the MAF?  :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 17 July 2013, 16:38:31 »
there was a very small amount oil i have had covers done and just changed dis pack 1-3-5 this is where oil was could it be dis pack not in correctly?
as said oil was a couple drops only and yes to code novice under the bonnet maf where that near?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 17 July 2013, 18:57:41 »
MAF plugs into the main pipe from airbox to front multirams iirc.
Was the knock sensor code cleared too?
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #4 on: 17 July 2013, 19:41:12 »
as far as aware done pedals got only 0300 now thanks
