Author Topic: Aircon compressor guide  (Read 1509 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
« on: 18 July 2013, 22:27:55 »
Big thanks to Hotel21 for the most recent guide  :y
Hoping to get mine looked at again next week. Not convinced this is the problem but if it is, then I'll maybe have an idea how to sort it  :y
Almost worth changing the seals anyway I guess, just to rule that out  :(
hotel21
  • The Kingdom of Fife
Re: Aircon compressor guide
« Reply #1 on: 19 July 2013, 11:50:44 »
Thanks for the thanks!   :)
Mine was loosing performance gradually and when I had it regassed last I made sure that dye was added at the same time. The dye ended up escaping round about the sealing washers and I was unsure if it was seals or compressor so ended up changing both.
Might be worth a dye check on yours as well?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #2 on: 19 July 2013, 21:30:45 »
Yes definitely. Can't be the pressure valve so soon, and it worked really well for a short time. I thought a leak test was part of the regas procedure, but maybe not. It's a pity you can't DIY the dye instead of having to rely on others. I'll ask for it this time though to make sure.
