Author Topic: Part number for GM Thermostat  (Read 1640 times)
PAULCDX
« on: 20 July 2013, 11:54:32 »
Hi,
Can anyone help me with the VX part number for a Thermostat for my Omega 2.2 2003 please?
I've seen some pattern / OEM ones on ebay but unsure they will fit or are the correct ones. Perhaps I should buy genuine GM ?
Thanks in advance  ;)
Paul  :y
Re: Part number for GM Thermostat
« Reply #1 on: 20 July 2013, 15:04:03 »
Thermostat Assembly (body & stat together): 90501081 :y
« Reply #2 on: 20 July 2013, 16:05:22 »
It nestles deep between the creamy bosom of the V6. :y
Not a ten minute job. :(
Ooops, Sorry. You have an Omega with two missing cylinders. ::) ::) ::) ;)
« Reply #3 on: 20 July 2013, 16:07:36 »
OP has a Desmond Opti, and it is literally a 10 minute job! ;D :y
Bloody Hell, you snuck that Edit in quick Opti! ;D
« Last Edit: 20 July 2013, 16:09:19 by PhilRich »
« Reply #4 on: 20 July 2013, 16:15:11 »
 I'm jealous.......why must the stat be so inaccessible on the V6?.... :-\ :-\ :y
PAULCDX
« Reply #5 on: 20 July 2013, 16:23:27 »
From memory the stat on the v6 is a bit if a barsteward so I'm glad I only have have the engine nowadays  ;D
Phil, thanks for the part number, I will take a look now  :y
chrisgixer
« Reply #6 on: 20 July 2013, 17:02:08 »
Its not the stat so much, its that poxy link pipe that rains on the paraid.
PAULCDX
« Reply #7 on: 20 July 2013, 17:50:30 »
True Chris  :D  ::)
PAULCDX
« Reply #8 on: 20 July 2013, 19:51:49 »
« Reply #9 on: 20 July 2013, 20:14:16 »
That is just the Thermostat itself Paul, however, they are very easy to fit in your existing body. QH is/was a a good pattern parts maker so there shouldn't be any problems there :y
PAULCDX
« Reply #10 on: 20 July 2013, 20:16:53 »
On looking under the part number you gave me Phil I couldn't find anything? Unless I was doing something wrong of course  :-[  ::)
I will keep looking tho or may even give AndyC a shout  ;)
PAULCDX
« Reply #12 on: 20 July 2013, 20:24:17 »
Cheers Phil  ;)
I'd put the wrong number in  ;D  :-[
