Author Topic: Fitting PFL/MFL Irmscher front bumper - does it use standard carrier  (Read 2540 times)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Hi guys
Does the PFL/MFL Irmscher front bumper use the standard bumper carrier - i.e. if I remove the standard bumper, leaving the carrier in place, should the Irmscher one just go straight on?
Cheers
sjc
  • Alloa, Scotland
Re: Fitting PFL/MFL Irmscher front bumper - does it use standard carrier
« Reply #1 on: 26 December 2014, 20:25:35 »
Anyone?
« Reply #2 on: 26 December 2014, 20:30:19 »
I would have thought so :-\ The facelift one certainly does, albeit with a modification to the foam padding :)
To add, the facelift one also has brackets to connect it to the wheel arch liner as it sits a couple of inches lower than standard, but otherwise uses all the same mounting hardware :y
« Last Edit: 26 December 2014, 20:32:20 by Taxi Al »
sjc
  • Alloa, Scotland
« Reply #3 on: 26 December 2014, 21:46:29 »
Thanks Al.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 28 December 2014, 17:21:53 »
the metal crash bar on the pfl car has to have parts of the crash bar removed to allow the irmscher spot lights to not foul against it. if you pm me your mobile no i will send you some pics to give you an idea of where to cut. also the horn bracket has to be turned around so to not foul the spots also.
Gary.
« Last Edit: 28 December 2014, 17:29:42 by ffcgary1 »
Jaguar XJ6
B-Buster
  • Netherlands
    • 3x Omega 3.0
    • OpelOmegaPortal (NL)
« Reply #5 on: 28 December 2014, 19:47:55 »
I had to modify mine.
to:
Result:
ffcgary1
  • Mitcham,Surrey.
« Reply #6 on: 28 December 2014, 19:59:26 »
yep as per the pics that roughly the same as my modified crash bar.
Jaguar XJ6
sjc
  • Alloa, Scotland
Cheers guys - that was what I was hoping cos that's what the bodyshop did to fit it and I thought it looked a bit iffy.
Greatly appreciate the replies.
