Worn ignition-solved
Started by omegod, 20 July 2013, 22:54:37
omegod
Had the old prob with ignition barrel getting sticky/clicky due to worn tumbler thingies, rather than start filing the burrs off them I swapped them for the identical ones in the glovebox lock, good as new! Left them out of the glovebox one as it's hardly thief proof anyway.
Quote from: omegod on 20 July 2013, 22:54:37
Not sure where the thread is now, but I bought new tumblers for a few quid ...... they are from your way somewhere.  :y
chrisgixer
Now that's a good idea. It seems to me. :y
My key is fine going in and put of the lock. Its turning it back and forth that feels awful. But only in hot weather. :-\
Must have a look some time. Another job. ::) :(
http://www.nwkeys.co.uk/Portal.aspx?page=43&cat=131&prod=7389
Can't find my thread, but this is the place I got new tumblers from. Just phone them , tell them how many of each number tumbler you want.  :y
Steve B
I like thay idea  :y :y
Quote from: chrisgixer on 20 July 2013, 23:10:24
That's common for Vauxhall locks(happens on BMWs too).  I've seen three in the last two weeks. Definitely time for maintenance/replacement before it stops working in a really inconvenient/expensive way
Quote from: Nick W on 21 July 2013, 10:26:08
Agreed. strip the barrel and deburr all the lock levers, then add a little graphite powder. Also make sure the little pin at the end is moving smoothly in the barrel casting.
Do this before it strands you, and it's an easy fix. ;)
ronnyd
Quote from: Kevin Wood on 21 July 2013, 10:40:57
[/quote
Had same prob the other day (30deg+) tried swmbo,s key, fine. Now it,s cooler mine is ok again :y
Had the same problem the other day, 30deg+, tried swmbo,s key, all ok. Mine is alright now weather is o bit cooler. :y
ronnyd
Re my 1st post- what the hell did i do? :-[
henryd
Quote from: ronnyd on 21 July 2013, 10:53:24
You posted inside the last posters quotes ::)
other rides
henryd
Quote from: henryd on 21 July 2013, 10:55:15
Re my 1st post- what the hell did i do? :-[  like this
other rides
ronnyd
Quote from: henryd on 21 July 2013, 10:55:41
Can,t even blame the weather as it,s quite cool here, sorry :-[
chrisgixer
So shall I have the AA waiting for me at Luton long stay on my return. After the car has been outside unused in 30c heat for 10 days?
That was my exact thought as i waved goodbye to it from the back seat of the bus.
Naah. It'll be fine. It's not as it it's a colour that absorbs lots of heat.. er...  :-[
Oyster next time, maybe?
