Author Topic: 2.5td fault code 92 and 96?  (Read 1349 times)
conalnugent
  • n. ireland
« on: 21 July 2013, 21:52:10 »
Got these  codes what are they?
Agemo
  • Cleethorpes
  • Insignia
Re: 2.5td fault code 92 and 96?
« Reply #1 on: 21 July 2013, 22:37:20 »
See here:-  http://www.omegaowners.com/forum/index.php?topic=90667.0
92       Cruise Control Device Circuit Open Or Voltage High - In my case, my cruise has stopped working, probably the stalk needs replacing.
96       Exhaust Gas Recirculation (EGR) Valve Out Of Range - I intend replacing the EGR, but may get away with just a clean.
These are common faults, and nothing to worry about.
conalnugent
  • n. ireland
« Reply #2 on: 21 July 2013, 23:38:59 »
Dont have cruise control. Egr, I 2p coined mine,  would this be causing the issue?
« Reply #3 on: 22 July 2013, 09:11:09 »
92 - no cruise stalk (you can add cruise to these by adding a cruise stalk (a special TD one))
96 - EGR. Ignore it if no symptoms.
