Author Topic: HBV  (Read 2885 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
HBV
« on: 22 July 2013, 15:30:12 »
Before the HBV finally gives up and dies are they prone to giving out hot air one side and cold the other from the vents ?..... Believe its gone now as steam wafting up from that area but had heat issues last few weeks
Re: HBV
« Reply #1 on: 22 July 2013, 16:08:03 »
Suspect a different problem unless it's losing coolant :-\
HBV failure is highlighted by coolant loss which increases/decreases depending on the climate settings :y
vauxsull
    • 3.0 Elite
Re: HBV
« Reply #2 on: 22 July 2013, 16:15:27 »
Only started to lose water today and steam everywhere but as i said permanent  heat on drivers side despite set to ' low'..... Hoping may have been linked somehow..
Re: HBV
« Reply #3 on: 22 July 2013, 16:22:29 »
Had four HBVs fail on me, and not one of them resulted in steam :-\
Split hose perhaps :-\
The temperature controls are vaccum motors in the front foot wells, above the front end of the centre console. It is not unknown for the arms to become disconnected.
vauxsull
    • 3.0 Elite
Re: HBV
« Reply #4 on: 22 July 2013, 16:25:41 »
is it an easy fix? will my cuppa tea go cold doing that job?
Re: HBV
« Reply #5 on: 22 July 2013, 16:31:24 »
Does the passenger side switch between hot and cold as expected?
vauxsull
    • 3.0 Elite
Re: HBV
« Reply #6 on: 22 July 2013, 16:59:15 »
yes it does
Re: HBV
« Reply #7 on: 22 July 2013, 18:32:09 »
Ok, remove the trim from under the glove box, and carefully reach over the front edge of the centre console, the servo is there. Ignition on, fan on its slowest setting and turn the passenger temp from Lo to Hi and back again. You should be able to see/hear/feel the servo moving the arm :-\
Do the same thing the other side, the servo should still move, but if the arm is detached, that won't move :y
Re: HBV
« Reply #8 on: 22 July 2013, 18:49:23 »
As Al says ^^^  or seats full back, get upside down in the seat, head in the footwells .....  you can just about see the actuators and the arms ... get someone to sit in the other seat and make the selections for you !!
vauxsull
    • 3.0 Elite
Re: HBV
« Reply #9 on: 22 July 2013, 19:00:48 »
ok guys i shall give that a go tomorrow.... i have just changed the HBV and im covered in scratches and sweating like gary glitter in a nursery....
Re: HBV
« Reply #10 on: 22 July 2013, 19:39:06 »
Clearly not trying hard enough, go stand in the corner
Re: HBV
« Reply #11 on: 22 July 2013, 19:40:06 »
Had four HBVs fail on me, and  ...
I've only replaced  mine twice in over 10 yrs  ???  ;)  ;)  ;)
vauxsull
    • 3.0 Elite
Re: HBV
« Reply #12 on: 22 July 2013, 19:53:42 »
I shall never attempt to do this again..... almost burst into tears on occasions
Re: HBV
« Reply #13 on: 22 July 2013, 20:08:01 »
Sorry Dad. Yes Dad :-[
 ;D
Re: HBV
« Reply #14 on: 22 July 2013, 20:17:08 »
Ya soft bugger!   ;D ;D
