Author Topic: 3.2 140a Alternator WTD  (Read 6367 times)
joshwyatt
  • Oxford
« on: 24 July 2013, 22:07:15 »
Can anyone help with the above?
Required is a 140a alternator for a 3.2. As long as it works, and the bearings are ok...it'll do...not asking for much am I?  ::)
The current one makes a terrible whining noise, and has very little life left I imagine.
Ideally, local to Oxford so I can pick up...but if not then I'll take a trip.
I would buy new, but after seeing the hassle Chris had with getting the correct one, I probably won't bother.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 3.2 140a Alternator WTD
« Reply #1 on: 24 July 2013, 22:10:10 »
Must be something in the air :o ...Just got mine back today and fitted after being repaired ( the 3.2 120a version )
« Reply #2 on: 24 July 2013, 22:41:35 »
Ive got a 3.2 with an alternator on it.Not sure if its 140A,but can check.
joshwyatt
  • Oxford
« Reply #3 on: 24 July 2013, 22:46:51 »
Thanks Albs  :y
    • 530D M Sport, 330i Coupe
« Reply #4 on: 24 July 2013, 23:02:04 »
Would be worth getting your existing unit refurbished as a spare or selling it to me so I can refurbish it as a spare!
« Reply #5 on: 24 July 2013, 23:05:05 »
Knowing what you've got in mind for it, you need all 140 amps :-X
chrisgixer
« Reply #6 on: 24 July 2013, 23:38:25 »
Customer ones are 120amp on the face lift elites. These are no longer available and the 140 amp is the part you "should" get from vx, if they label it up correctly.
Referring is the cheaper option of you know where to send it, or where to get the parts for diy. Kev has details of a parts supplier. Or Mr omega man sent his off locally.
Bit of a delay waiting for parts to arrive I guess, but you pays your money.... :)
chrisgixer
« Reply #7 on: 24 July 2013, 23:40:50 »
Referbing is the cheaper option if you know where to send it, or where to get the parts for diy. Kev has details of a parts supplier. Or Mr omega man sent his off locally.
Sigh...
« Reply #8 on: 25 July 2013, 08:10:51 »
I have a facelift alternator in the garage, not sure what amps it is though
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #9 on: 25 July 2013, 08:44:30 »
Out of interest, what the difference between the 120 and the 140 amp alternator ?
Just the regulator ?
If so, can you upgrade a 120 by swapping the regulator's over ?
« Reply #10 on: 25 July 2013, 11:05:14 »
Im sure RobG says the 120a is much more reliable than the 140a. Not sure why though. :-\
« Reply #11 on: 25 July 2013, 14:55:10 »
The one from the 3.0 is more reliable with regards to regulator failure and reg is a lot cheaper too
« Reply #12 on: 25 July 2013, 16:19:52 »
Its a different reg setup (looks a different make), the 120 is MUCH more reliable and cheaper to repair.
chrisgixer
« Reply #13 on: 25 July 2013, 16:35:32 »
Within the superior 3.2's there's not much difference. Its the pre face lift Alternator on the v engines that last longer.
(Although my 2.5 failed well early if that the same part)
chrisgixer
« Reply #14 on: 25 July 2013, 16:36:09 »
I be
I believe...
Page created in 0.029 seconds with 20 queries.
