Pages: 1 2 [3]  All   Go Down
Author Topic: 2.2 Operating running temperature  (Read 5899 times)
PAULCDX
Re: 2.2 Operating running temperature
« Reply #30 on: 04 August 2013, 19:39:20 »
Thanks  :y
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #31 on: 05 August 2013, 10:00:49 »
Is this thread about the 2.2 petrol or diesel?
PAULCDX
« Reply #32 on: 05 August 2013, 10:50:33 »
2.2 Petrol sorry  :-[
chris6124
  • Donegal
  • omega 3.0 mv6
    • vauxhall omega 3.0 mv6
« Reply #33 on: 08 August 2013, 03:40:41 »
i have a 2.2 petrol also. when you sit idleing for a long period of time she will reach 100 and over. what would my problem be here?
« Reply #34 on: 08 August 2013, 08:45:59 »
Fans not coming on, that is way too hot! I'd investigate that ASAP  :y
PAULCDX
« Reply #35 on: 09 August 2013, 17:05:42 »
Sat idling for over half an hour and watched the temp gauge reach 95 before fans kicked in and then needle came down to 90.
Once the car has reached it's operation temp after twenty mins or so she will sit between 90 / 95 all the time??  ???
Normal? I'm not convinced  :-\
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« Reply #36 on: 09 August 2013, 17:39:54 »
Normal I would say, exactly the same as my 2.0 mfl
« Reply #37 on: 09 August 2013, 18:32:43 »
Drain the coolant and flush the rad and block out , change the stat and job jobbed  :y
PAULCDX
« Reply #38 on: 09 August 2013, 18:36:33 »
I've got a new header tank and coolant to use, just need to buy a new thermostat then hopefully will sort this out  ::)  :y
Pages: 1 2 [3]  All   Go Up
