I'm on the V6 trail, tempted by this one?
Started by PAULCDX, 31 July 2013, 19:35:33
Expensive for a car with no MoT :-\ budget for rocker covers, steering/suspension work and at least one tyre...
Good project car though :y
PAULCDX
He has told me £400 as is or he will MOT it at buyers cost  ;D
Gut feeling stay away Al?
I should have just bought a V6 in the first place  ;D  :D
If he is sooo confident that an Mot will be fine, then he should put it through...
Wouldn't pay much over £300250 max personally  :-\
PAULCDX
He offered to put it through but at my cost he said, thinks it just needs a tyre and rocker cover work but due to the distance it would be a huge gamble on my part I guess..
I'd be tempted to offer him what you said just over £300 as it is to be honest......... He's had it a while and can't sell it??  ???  ::)
Edited my last :y
Rocker gaskets could be as simple as not fitted properly, and while a new tyre will help with the MoT, it won't fix the cause of the wear....
PAULCDX
I see where you are coming from Al, thanks for your thoughts  :y
Prob due to the distance I will leave this one but I did like it because of the price, spec, leathers, and it was a 2003 for £400  :o
Or should I will insult the seller with a lower offer?   ;D
PAULCDX
PAULCDX
Spoke to the chap this morning and he won't budge much, lowest he said is £400 as is  :o
He's now put it on ebay £450 buy it now  ::)  ???
PAULCDX
Wonder if this one could be better and what the problem is? Has an loss of oil issue, any ideas from description ?
http://www.ebay.co.uk/itm/OMEGA-ELITE-V6-2-6-51-REG-/141020011673?pt=Automobiles_UK&hash=item20d5729c99
Paul  :y
Does sound like stem seals , had the same issue on my 2.0 . 16 stem seals replaced and jobs a good un  :y A bit steep on price i would have thought for that though  :-\
PAULCDX
Steep price, That's what I thought tbh  ::)
Is the repair an expensive fix inc parts ?
What's she worth ideally?  :y
Ahhh i just seen the add says make off too  :y If it was me i would offer £350 an budget for £2-300 for repair depending on how bad the seals are if it is that  :-\ Best to have a look at it first and see how bad the smoking is  :y
Second thoughts  ;D If it was me id get a non smoker  ::) Plenty out there cheap enough ..
PAULCDX
