Weight od a V6 ?
Started by albitz, 01 August 2013, 20:29:49
As above.3.2 V6 engine. Anyone know the weight of one please ? Someone wants me to send one to Cheshire !
RobG (the burfday boy) to Carchat please. ;D
henryd
According to Woody on the old site its 115~150kg depending whether any ancillaries fitted :y
other rides
Reckon on 175Kg absolute top end
Yeah, my guess would be around 160-170 Kg.
If you're going to strap it to a pallet be sure to clean and drain it first :y
A couple of cheapy ratchet straps will hold it down, and if you have access to some, wrapping it with industrial cling film will offer a degree of protection :y
Good advice thanks Al. :y
It will be empty of fluids and minus ancilliaries apart from starter motor.
symes
Quote from: ex taxi al on 01 August 2013, 20:56:54
or old seat belts ;)
For an idea of cost try this firm...
http://www.karl-king.co.uk/Pall_Ex_Network.htm
The firm I usually work for is a Pall Ex member :y seems to be a reasonable way to send bulkier things around without braking the bank, and being smaller local firms, you actually get service :y
Which is nice ::)
Quote from: RobG on 01 August 2013, 20:39:01
Bloody hell......some litre superbikes weigh less than that. :o :o :o :o
C25XE 176 kgs   so an assumption of 180 kg wont be far :y
ps: someone weighted x25xe without flywheel, exhaust manifold, alternator, power steering, ac compressor and oil  is 150 kg
http://www.omegaowners.com/forum/index.php?topic=106448.0
Keith ABS
   D W Clark down in Little Totham are in the Pallex network. Not far away mate
Keith B
Thanks Keith.Will bear that in mind. :y
Presumably all they do is take a percentage, and run it through Pall Ex or Palletline :-\ might as well cut out the middleman and book locally...
