Author Topic: What happens if?  (Read 1034 times)
  • Online Online
What happens if?
« on: 03 August 2013, 13:38:31 »
I put expired AA batteries into a charger suitable  for rechargeable batteries only?
Re: What happens if?
« Reply #1 on: 03 August 2013, 13:42:51 »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 03 August 2013, 13:44:08 »
If they are properly flat, they'll more than likely leak and cause problems.
If they are partially charged, they 'should' fully charge.
« Reply #3 on: 03 August 2013, 13:46:25 »
Nothing other than giving them a boost which will make them last a bit longer, at least for the first couple of times you do it! You may then find they have leaked their highly corrosive contents into whatever device they're fitted to :P :y
  • Online Online
« Reply #4 on: 03 August 2013, 13:50:00 »
I've tried it before, but only for about ten minutes at a time. It did seem to breathe  life into them.
I'm not sure about leaving them charging for hours though, after seeing the picture that Mr Tunnie posted.. :-\ :-\
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 03 August 2013, 13:59:58 »
Can you adjust the output of the charger?  If you can, 50MAh for 10-12 hours would trickle charge a standard Alkaline battery to almost 'new'.
Modern chargers are relatively speaking high output (~200MAh)..... I'd advise against charging normal batteries if there is no adjustment.
  • Online Online
« Reply #6 on: 03 August 2013, 14:07:23 »
No, BM. It's just your standard 'ten a penny' Uniross charger.
Output for AA batteries is quoted at....... 2x 2.8V......145-160mA  0.448VA........whatever that means.
