Sump Sucker
Started by omega3000, 03 August 2013, 17:26:11
Bought a siphon kit , only a 5ver . Specifically for drawing out the old brake fluid but as its a kit its got the pipes to feed down the dipstick and do an oil change  :o Now its tempting to use the function but im sure you will all say no  :-\
Don't like em myself,but Im probably old fashioned. ;)
I bought a Pela 6000 specifically for SWMBO's Smart that doesn't have a sump drain plug. I also used it yesterday to do my sister-in-law's Astra, because GM, in their infinite wisdom made the drop down flap on the lower engine cover, that big, that it hits the ground way before you can get to the drain plug - intended for use when the car is in the air on a 4 poster lift ..... and not ramps.  ???
ronnyd
How long does it take to empty a Mig sump then? ???
Quote from: ronnyd on 03 August 2013, 17:53:49
I'm not exactly sure how long it took to remove 5 litres from the Astra .... you set it off & then get on with something else. It's not long though ..... 10 mins maybe  :-\ :-\
And on an Omega it'd be best to empty the Pela part way through, otherwise you'll end up with oil getting sucked up into the vacuum pump ..... like I did yesterday - there must've been a bit still in the bottle when I started.  ::)
ronnyd
Sorry to be a bore, but what is the Pela please? :-[
ronnyd
Sorry Andy, i didn,t read your previous post correctly, it,s an age thing don,t ya know. ;D
Quote from: ronnyd on 03 August 2013, 18:10:59
only too well  :-[  ;D  ;D  ;D
henryd
I prefer to drain properly but use the sucker on mostly Vag cars because there undertrays are a pain in the ass once 5-6 years old :y
other rides
Quote from: henryd on 03 August 2013, 18:45:56
I can't say for every car, but on her Smart, there's bugger all left in the sump after the sucker has been used.
henryd
Quote from: Andy B on 03 August 2013, 18:57:59
I've checked on golf's and A4's with 1.9pd lump and it drains them completely, later 2.0Td's leaves about a litre behind so have to drop there trays and do it proper :-\
other rides
Often used on boat engines due to space restrictions, some even have inbuilt pumps specifically for servicing purposes :y
Whether a good idea or not on cars however, I am less convinced :-\
Quote from: Emd on 03 August 2013, 17:26:11
....but surely you still have to get underneath to access the filter.
