Author Topic: Do V6 aux belt tensioners vary?  (Read 1764 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 05 August 2013, 08:47:55 »
X84GNB 2000 2.5 manual petrol estate
On changing my cam belt I had planned to replace the cracked cam belt cover with a spare I took off a scrapped 1999 3 litre. It fitted all right, but I could not get the auxiliary belt tensioner on. I replace the original cracked cam belt cover and the tensioner went on The cam belt covers looked the same. This puzzled me.
This morning I wonder, would the tensioner off the 3 litre have fitted? Do they differ?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Do V6 aux belt tensioners vary?
« Reply #1 on: 05 August 2013, 12:54:27 »
2.5/3,0 should be the same part.
other rides
chrisgixer
« Reply #2 on: 05 August 2013, 13:04:44 »
There's a bracket on the same bolts. Could that be interfering with the fit?
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 05 August 2013, 19:09:03 »
The bracket on the lower bolt for the wiring harness guide was no trouble. It seemed as if the new belt cover was too far forward to allow the bolts to engage in the threads. I put back the old cover, bolts went straight in. Covers looked both the same.
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 05 August 2013, 22:01:08 »
covers are different mate-only mm's I know-had same problem :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 05 August 2013, 22:26:38 »
Thank you. So would the aux belt tensioner off the 3 litre have  fitted with the 3 litre cam belt cover, or are the threads in a different place on the 3 litre? I think I kept the tensioner off the 3 litre too, but it never occurred to me that they might vary.
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 05 August 2013, 22:33:02 »
dont know mate-only know about the cover :y-just swap pulleys :y
