Author Topic: V6 oil cooler replacement  (Read 1689 times)
judge_dredd65
  • Selby, North Yorkshire
    • Omega 3.2 MV6 ,Irmscher
« on: 07 August 2013, 21:04:25 »
I have had an oil cooler fail on me for the second time in six months, (the replacement was second hand so i think i have just been unlucky), I am thinking about replacing the original oil cooler with an aftermarket universal oil cooler. Has anyone any experience of this and if so is there an oil cooler kit they can recommend.
Thanks in advance
kevinp58
  • kent
    • 2002 3.2 elite
Re: V6 oil cooler replacement
« Reply #1 on: 07 August 2013, 21:06:47 »
Never use a second hand one always use a NEW genuine one and ancilleries.  :y
« Reply #2 on: 07 August 2013, 21:17:20 »
Later oil coolers are stainless steel, was the replacement also stainless? (Fitted to 2.6/3.2's)
Cooler failure is down to pure neglect of coolant maintenance, are you using a good 50/50 mix of water & antifreeze?
« Reply #3 on: 07 August 2013, 21:20:21 »
Ive had some doubts about this recently,as Ive seen several 2.6/3.2,s with failed oil coolers.In fact I have one sat on my drive at the moment.
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #4 on: 07 August 2013, 21:53:48 »
Nothing noted on EPC, except that you can no longer get the oil cooler on its own, it now comes as an assembly with the plate already attached.
Perhaps AndyC knows more.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 07 August 2013, 22:12:09 »
Ive only ever come across 2 failed coolers, an 03 3.2 and a 02 2.6 so I also have doubts about the late one being any different :-*
« Last Edit: 07 August 2013, 22:13:50 by zirk »
