Author Topic: stag software question  (Read 2804 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 07 August 2013, 21:08:53 »
Just being re building my notebook after a win 7 upgrade  :-X
Noticed that the ac stag software number has changed to 9.3.0.1.
Is this the latest / final upgrade for the stag 300 plus / isa controllers ?
Mines running 9.1.0.1 or something like that at the moment
Tia
Re: stag software question
« Reply #1 on: 07 August 2013, 21:18:33 »
Mine appears to be 1.14.1.0 - whatever it is,it don't facking work. :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 08 August 2013, 08:02:09 »
That's the software for ecu's manufactured before November 2009 Albs  :)
What's up with yours anyway ?
« Reply #3 on: 08 August 2013, 09:47:15 »
Sounds about right then.Mine would predate that. The software worked fine for the first few months.Didnt use it for approx. 18 months.Plugged lappy & lead onto car a couple of months ago,and constantly got "no LPG controller" message. ???
« Reply #4 on: 08 August 2013, 20:53:51 »
The programme Driver has probably become corrupted Albs. If you still have the software disc you can do a re-install or look for a copy on 'tinternet :-\
« Reply #5 on: 08 August 2013, 21:37:48 »
Not sure if I had/have the disc.LD sorted it all out on my lappy for me.
Will have a browse on tinternet when I get time. :y
« Reply #6 on: 08 August 2013, 22:41:46 »
Search for AC lpg USB driver and download it from the AC site ;)
« Reply #7 on: 08 August 2013, 23:22:03 »
Done. :y
Was the same version,but uninstalled what I had and downloaded and installed again.Will have a play in the morning and see what happens. :y
« Reply #8 on: 09 August 2013, 10:51:56 »
Didn't work,still the same.Plug the lead into the usb port.Both lights on the little black box flash twice then stop. :(
« Reply #9 on: 09 August 2013, 11:18:38 »
Albs, have you tried changing the Port connection in the software ???
Top left hand corner of Main Software page is the 'Port' button. Open this & select different types of connection one at a time & see if it then recognises the ecu. Apologies if Grandmother & Suck eggs applies :-[ ;)
« Reply #10 on: 09 August 2013, 11:44:02 »
Didn't know about that option.Will give it a try,thanks Phil. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 09 August 2013, 11:53:08 »
Had a similar problem with jusme's last month.
I left the engine running with all connected then removed the stag ecu fuse for a few minutes.
Replaced it then re started the stag software on the laptop and it connected straight away.
Albs, remove the software off your laptop, re boot it then download it off this site ................
The bit you need is under the "Attention bit"
http://www.autogas-lpg.co.uk/content/11-Download-STAG  :)
Just remembered ................... had a similar problem with my laptop a few months ago.
Got to the point where I idioted the usb module with percy and ended up getting a new one off ebay.
Plugged that one in and it downloaded the driver off t'nternet straight away without any problems
« Last Edit: 09 August 2013, 11:57:55 by tigers_gonads »
« Reply #12 on: 09 August 2013, 11:56:24 »
Removed old,and downloaded that last night. Will try the fuse trick. :y
And sorry for hijacking your thread. ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 09 August 2013, 12:09:23 »
No worries  :)
I didn't get the answer anyway so i'll plug it into mine and see if the controller updates  ;D ;D
Best hide percy first or i'll be another 30 quid out of pocket  :D :D :D
« Reply #14 on: 09 August 2013, 12:32:23 »
Tried the fust trick and port -discoonect/connect.No change. Lights on interface box flash quickly as you would expect,until the lead is plugged into the port.Then they blink twice,go off,and "no controller" message appears on screen. :-\
