Author Topic: Rear drop links  (Read 1442 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Rear drop links
« on: 07 August 2013, 21:11:18 »
How do you get it off. Tried today but couldn't get drivers side off. Got bottom bolt out easy but couldn't get off the roll bar sprayed with wd40 but still couldn't get it off. Any ideas please,
 cheers Ian
Re: Rear drop links
« Reply #1 on: 07 August 2013, 21:14:08 »
Never had an issue, it just pulls out from the suspension arm?
plym ian
  • Plymouth, Devon
Re: Rear drop links
« Reply #2 on: 07 August 2013, 21:37:51 »
Got the bottom out no probs it's the top one I have the issue with cant get it off
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: Rear drop links
« Reply #3 on: 07 August 2013, 21:48:02 »
You'll just need to keep at it mate - the rubber can bond itself to the bar.  Of course, method of removal will depend on what you need to re-use  ;)  Try a long-reach socket over the end of the bar to knock it slightly further on, this should free it off and let you remove it.
plym ian
  • Plymouth, Devon
Re: Rear drop links
« Reply #4 on: 07 August 2013, 22:15:28 »
Will try the socket I'm replacing them anyway :y
