Author Topic: cracked manifold.?  (Read 4170 times)
chris6124
  • Donegal
  • omega 3.0 mv6
    • vauxhall omega 3.0 mv6
cracked manifold.?
« on: 08 August 2013, 03:32:31 »
there is a large crack on the top of my manifold, the car is a 2.2 gls. she seems very low on power and is very sore on fuel. anyone know will fixing this solve both problems ?
Re: cracked manifold.?
« Reply #1 on: 08 August 2013, 07:21:28 »
Probably. :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 08 August 2013, 07:29:51 »
I doubt it. I have had three 2.0 Omegas with cracks exhaust manifolds (on top, under the heat shield) and while the spotting noise at idle was annoying there was no obvious decline in performance.
I currently have a 2.5 Omega with a cracked RH exhaust manifold. The crack occurred suddenly two years resulting in a spitting noise idling cold, but diminishing when hot. It has got worse, growling all the time. I have now obtained a second hand manifold and shall change it when I can find the courage. The performance has not changed a bit.
« Reply #3 on: 08 August 2013, 08:25:04 »
Big car + 4 pot , a bit like the old 2.0 granada's .. will always use more fuel  :y 4 pots seem to suffer with the cracked manifold problems though ..  :(
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 08 August 2013, 19:38:13 »
I had a leaking EGR pipe. that affected fuel economy big style. replaced it, fuel consumption now pretty good... well after its heated up for two mins... I cant get to the nut to tightem it enough  :-[
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 08 August 2013, 20:59:21 »
when you get over here will attack that nut :y got a magic tool made by wizards :y :y iits so secret if i told you they would cast spells on me :-\
« Reply #6 on: 08 August 2013, 21:38:54 »
Only thing I thought of to tighten that nut might be a crows foot spanner,but I don't have one that big. :-\
« Reply #7 on: 09 August 2013, 11:21:39 »
Sounds like Symes 'Magic tool' is made from a real crows foot :D ;D ;D
« Reply #8 on: 09 August 2013, 12:11:07 »
 ;D ;D ;D
Webby the Bear
  • Northampton
« Reply #9 on: 09 August 2013, 12:56:41 »
haha nice one symes :)
i'm thinking we'll have better access once we strip it down to just the cam cover.... :)
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #10 on: 09 August 2013, 22:44:35 »
wait and see ;) ;)
chrisgixer
« Reply #11 on: 10 August 2013, 06:16:48 »
The 2.5 issue is probably just the gasket failed. My old 2.5 did the same.
« Reply #12 on: 10 August 2013, 09:53:11 »
 :o ;D ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #13 on: 10 August 2013, 22:50:17 »
I hope you are right, but I doubt it. It happened so suddenly. I suppose a stud could have broken.
chrisgixer
« Reply #14 on: 10 August 2013, 23:07:19 »
Hmmm, that's not so normal. Usually, it sounds a bit futty on start up, which disapears as it warms up. The worse it gets, the longer it takes for the noise to subside. Until eventually, it never stops and constantly blows.
