Author Topic: MoT  (Read 2345 times)
Bob G
  • Gloucester
MoT
« on: 10 August 2013, 12:31:42 »
Well she flew through it today, 2 small advisories offside rear calliper sticking and handbrake adjustment, sure the "how to do it" will be on here  :D
Re: MoT
« Reply #1 on: 10 August 2013, 12:59:20 »
Happy days :D
Excellent guide to handbrake is on the site, but you can't take shortcuts.  Its quite time consuming the first time...
Bob G
  • Gloucester
Re: MoT
« Reply #2 on: 10 August 2013, 14:12:24 »
found that guide, does all that need to be done to adjust it, just so I don't do stuff that might not need it?
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: MoT
« Reply #3 on: 11 August 2013, 13:31:01 »
Yes, afraid it does.
I assume, you found this guide...
http://www.omegaowners.com/forum/index.php?topic=90580.0
Note the comment that saves you having to remove the heat shields: "Some people also prefer to use a socket on a long extension to obtain access to the handbrake cable adjuster."
Re: MoT
« Reply #4 on: 11 August 2013, 14:03:50 »
Always good to hear :y
  • Auckland
    • Mazda MPV
Re: MoT
« Reply #5 on: 11 August 2013, 14:27:40 »
Note the comment that saves you having to remove the heat shields: "Some people also prefer to use a deep socket on a long extension to obtain access to the handbrake cable adjuster."
Fixed that for you. ;)
I found that a normal socket couldn't reach the flats on the adjuster nut because of the threaded rod projecting through the nut.
With a deep socket I was able to concentrate on adjusting the parking brake without having to first shear off remove about 20 little nuts to get the heat shields off.
sjc
  • Alloa, Scotland
Re: MoT
« Reply #6 on: 11 August 2013, 14:48:09 »
LOL, you might have gone the whole hog and given the socket size too!
(It's a 13mm if I remember correctly)
Bob G
  • Gloucester
Re: MoT
« Reply #7 on: 11 August 2013, 17:15:22 »
Thanks for the replies one and all, decided it would be stripped anyway as the binding could be calliper or could be handbrake, or would you all disagree ;D
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: MoT
« Reply #8 on: 11 August 2013, 17:17:36 »
Was the handbrake advisory due to limited excess travel or due to inefficiency?
Bob G
  • Gloucester
Re: MoT
« Reply #9 on: 11 August 2013, 17:49:48 »
was about on its limit of travel
Re: MoT
« Reply #10 on: 11 August 2013, 18:24:22 »
Tis indeed 13mm :y
Re: MoT
« Reply #11 on: 11 August 2013, 20:47:26 »
My Cavalier is booked in for its test at 4pm tomorrow.Thats going to be a real "wing & a prayer" job. ::) ;D
It doesn't owe me anything,but I would hate to have to scrap it.It saves me a small fortune,and Im kind of getting attached to the old rusty heap of sh1te for some reason. Twiglet did warn me that would happen. ::)
