Been offered an R reg 1998 Volvo V70 XC Auto Estate Petrol, any good??
Started by The Waynester, 11 August 2013, 21:02:44
The Waynester
Hi Guys
just been offered a used car I have found on the internet
its going for £575
its a
R Reg 1998 VOLVO V70 2.5 XC AUTOMATIC ESTATE PETROL
MOT UNTIL JUNE 2014
TAX NOVEMBER 2013
147,788 MILES, FSH
BLACK LEATHER SEATS, ALLOYS WITH FAIRLY NEW TYRES
AIR CON NEEDS A RE GAS APPARENTLY
I have never owned a Volvo before, I am coming from an S Reg 1998 Vauxhall Omega CDX Estate 2.5 V6 Petrol with 103k
still use it daily, does 30mpg, but body is showing its age, rust on doors and wheel arches
the Volvo for sale has no rust
can anyone tell me how good these V70s are? or avoid like the plague?
are they quiet to drive? I do like "low cabin noise"  like my Miggy :y
0795omega
great cars,good high mileage coverers,only thing rear interior trim can be a bit noisy,but easily sorted i suppose with new trim clips! i had an 850 turbo once was a great car.
Found this after a quick Google Wayne, it's a well documented problem on early V70's :y
"1999 was the first year of the electronic throttle module (ETM). Volvo used a module made by Magneti Marelli (along with a Denso air mass meter) from 1999 through 2001. Some early non-turbo 2002s also used this ETM before Volvo switched to Bosch parts. These early ETMs can exhibit failure, but they are subject to an extended 10 year 200,000 mile warranty for the Canadian and US markets. Revised software seems to have eliminated the problem. The cause has been explained to me as software that detected throttle resistance as dirt accumulated (or perhaps wear as well). The fix was to eliminate the resistance limits from the software. Volvo dealers may recommend a regular cleaning. DIY'ers should be careful to use throttle body cleaner, not carburetor cleaner."
The Waynester
this ones a March 1998 Model mate, think it`d be okay?   :-\
thankyou for doing that research   :y
hoody
a lot of them have had the 4 wheel drive disabled and the autobox was a known weakness on them.The engines make a great noise and they are a nice place to be inside but as i said a lot have been converted to fwd and make sure the autobox does what it should.
2woody
I'll second that.
Generally, they're reasonable fun to drive, despite being wrong-wheel-drive. Handling is still way off Omega prowess, tho. You should have a word with yourself for thinking of an atuo, tho.
built like brick netties
