Author Topic: Plumber question/advice  (Read 999 times)
Big_Al
« on: 12 August 2013, 21:41:56 »
hoping someone with better plumbing experience than me can help here
I need to fit a twin impeller 1.5 bar shower pump in the bottom of hot water tank cupboard to pump a single shower.
Using a Surrey flange to eliminate air to pump . Seperate cold feed from loft tank for cold to pump .
If I route the hot & cold " post " pump shower feeds up from the pump into the loft & over to the shower , will I have any additional
problems.  distances are 8 feet up the wall ,   10 feet to shower wall & 4 feet back down to shower  mixer
Much easier this way as flooring has had new carpets recently & flooring is 2400 x 600 chipboard sheets , so will be a nightmare to go across landing to en suite through the floor  :(
TIA   Al ;)
Re: Plumber question/advice
« Reply #1 on: 12 August 2013, 21:46:35 »
Works fine, worth fitting some air bleed points at the high points although with the boosted pressure air soon exits and obviously insulate the pipes.
Big_Al
« Reply #2 on: 12 August 2013, 21:59:27 »
Thanks,  thought it would be ok , just wanted a 2nd opinion .  Also will lag pipes  :y :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #3 on: 12 August 2013, 22:06:45 »
Yep, works fine.  :y That's the same set up that I did a few years ago. I put full bore isolators pre-pump to make it easier if I have any issues later on. It also allows you to work on it at your leisure once you have fitted the isolators.  :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 12 August 2013, 23:01:49 »
Yes agree with fitting the bleed point in loft.
AndyRoid
  • Hants
« Reply #5 on: 13 August 2013, 12:39:10 »
Is the spur for this pump already wired and suitably protected?
If not, you will need a qualified sparks who can install, test, and sign it off.
