Author Topic: cam cover gaskets  (Read 3752 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
cam cover gaskets
« on: 13 August 2013, 17:59:33 »
 do we know the part no. for cam cover gaskets for a facelift 03 V6 also the black sealant part no. would be useful. I think I have been given the green stuff.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: cam cover gaskets
« Reply #1 on: 13 August 2013, 18:04:48 »
Further to my post a list of all  part nos for the gasket/rings for the inlet system would be useful That is all rings needed to fit a new thermostat from plenum down .
« Reply #2 on: 13 August 2013, 18:11:01 »
You need black goo :y
Are we still meeting on 16th? :y
« Reply #3 on: 13 August 2013, 21:09:11 »
All the cam cover part numbers, and inlet gasket part numbers are in the cam cover guide: http://www.omegaowners.com/forum/index.php?topic=90542.0
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 13 August 2013, 21:29:05 »
The inlet and plenum seals should be re-usable, unless you really want to change them.  :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 13 August 2013, 21:30:48 »
+1 :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 14 August 2013, 11:35:03 »
Been back to supplier changed cover gaskets and sealant. Hope its right now.
« Reply #7 on: 14 August 2013, 18:23:05 »
Genuine gaskets?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 14 August 2013, 18:31:38 »
Genuine gaskets?
cue ralf and tunnie  ;D ;D ;D
RIP Paul Lovejoy
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 14 August 2013, 19:28:35 »
Yes all GM.
bored bigyin54
  • south wales
    • black beast
« Reply #10 on: 14 August 2013, 19:49:57 »
Genuine gaskets?
no comment webby  ;D ;D
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #11 on: 15 August 2013, 08:41:30 »
Just like to point out that the 2.6 has a change over as far as cam cover gaskets go on engine numbers so make sure that you are supplied with correct type. Sorry if everbody except me knows this.
pauls
  • By the sea minehead
    • Bmw x3
« Reply #12 on: 15 August 2013, 14:11:23 »
Didnt know how do you find out which ones
symes
  • oxford
    • R reg 940 volvo
« Reply #13 on: 15 August 2013, 14:21:09 »
2.6 gasket does not have half moon shape on gasket :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 15 August 2013, 15:10:46 »
the gasket I was given was 55351456 This is  a double seal ie the two halves are joined with a bridging piece I checked on what I used when I first bought the car and these are 090511451. two seperate seals . Both however have half moons how would you get an oil seal without them.As I said there is a change over on engine nos.
