Author Topic: Automatic gearbox prolem  (Read 1328 times)
peter1971
  • paisley
    • omega
« on: 15 August 2013, 15:59:05 »
Hi im a bit puzzled by a problem ive got with my automatic gearbox when I first use the car its fine but then when I switch it off and go back to use it when I put it into drive its as if its in top gear I don't have any warning lights or anything showing up then if I leave it maybe a few hours then use it put into drive it could be fine again does anybody have any ideas whats up thanks
chrisgixer
Re: Automatic gearbox prolem
« Reply #1 on: 15 August 2013, 21:22:25 »
Snow mode button lit when it plays up?
« Reply #2 on: 15 August 2013, 21:24:20 »
Any warnings on the computer display (or the Gearbox Fault light illuminated under display if its GLS or ex-plod)?
peter1971
  • paisley
    • omega
« Reply #3 on: 15 August 2013, 22:03:49 »
Hi no warning lights and all the lights are as should be when it goes like this you can't press the sport or winter button
chrisgixer
« Reply #4 on: 15 August 2013, 22:16:17 »
Limp mode then.
Get a code reader on it capable of reading gear box ecu. And check the fluid level, guide in maintenance.
...IMO. :)
peter1971
  • paisley
    • omega
« Reply #5 on: 15 August 2013, 22:39:12 »
Ok but it was supposed to have been changed but will have a look any idea if that's all ok
